My printer, just before it attempts to print, make a loud hum and then dies with an "online/error" light. Checked for paper jams...nothing. Pulled the toner out etc. No indication apparent.
Windows ME: no print, instead of it - the msg as follows:
All system checks give the same result "all is OK".
internal error - false
Position ox21e (542)
SYSTEM: h6fwsim_mono/x1_image
LINE: 132
Version: QPDL 5.04 04-25-2005
Can anyone suggest whats the solution?
But please don't advice driver reinstall, done many times with no result.Windows ME: no print, instead of it - the msg as follows:
the printer produce this error page if i try to print more than one or two pages in a job. The toner cardridge was changed any days before. I don't believe, that this will be the reason for.the printer produce this error page if i try to print more than one or two pages in a job. The toner cardridge was changed any days before. I don't believe, that this will be the reason for.
You can't post conmments that contain an email address.
Mine did the same thing, turned out to be an empty toner cartridge. The one that comes with the printer when you buy it only prints about 50 sheets before it dies.
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see "Clearing
Paper Jams" on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See "Installing the Toner
Cartridge" on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
First open all covers and make sure there is not another piece of paper stuck in the machine. Check under the toner cartridge. If you are sure there is no other paper stuck, try unplugging the machine wait about a minute and plug back in.
LINE: 132
