Question about Nokia 7370 Cellular Phone
Plugged in headphones for call, now earpiece doesn't work
I plugged in my Nokia 7370 headset in anticipation of a call (this was the first time I used the headphones), but now that I've removed them, my phone's earpiece sound no longer works. I cannot hear callers speaking, nor the sounds from pressing the numbers. The ringtone and alarm sounds still work, I can still hear callers fine through the headphones, and I've checked all the volumes. It's almost like the earpiece turned off for headset use, and now it won't turn back on (or else I shorted something out). Any help? Many thanks!
  • 1 more comment
  • Anonymous Mar 17, 2008
    Mine is doing the same
  • MyWifesPhone Jun 22, 2008
    Same problem here - removing battery n sim didn't work. Have blown out/cleaned pop port but still no joy. Only had phoen for 1 month!!
    Any assistance appreciated.
  • Anonymous Jul 17, 2008
    Same here. I tried many things but cannot ring it back to headset mode.
    I continuously see the headphone icon shown in the phone, so it seems
    that the phone thinks that it is still connected to earphones.
    Sometimes, it works fine, but mostly it does not. If I connect the
    phone on bluetooth earphones, it works fine.
    Any help will be appreciated.
    Accidentally posted the above as a solution. Will try to remove "the solution" bit. If I can't, please ignore the previous post by me.
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Posted on Jul 17, 2008
SOURCE:
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Why does my volume not return to normal levels after using a motorola headset? Is there a way to return the unit to factory settings?
the volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
Nov 12, 2014 | Motorola Talkabout MT352R Two-way Radios,...
SPEAKERS DOMT WORK SINCE USING CS 100 HEADSET
Is your headset plugged into the jack on your headset for speakers? If so, they won't play as long as the headset is plugged into them. Once you unplug them, they will play again. It's an either/or situation, as they assume nobody wants headphones and speakers to play at the same time.
If that's NOT the case, please supply more information.
Mar 29, 2014 | Koss CS-100 Headset
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
I couldn't hear the voice of the caller wen sumone calls me... bu i can play music player nd use loud speaker. I use nokia 3110c.
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Sep 01, 2010 | Nokia 3110 Cellular Phone
Nokia 6020 is displaying headphones and can not ring when a call comes in. when i answer i dont hear anything on earpiece and the caller also can not hear me
Open youre phone and clean with one bresh, headphone connecting area with sprit(diluted),conendac tcleaner ore petrole you can youse for cleaning
Aug 23, 2010 | Nokia Handsfree For 6020, 6101, 6102...
I just installed a Logitech Quickcam. It came with a headset that has 2 plugs, one for mic, one for earpiece but my speakers only have one outlet for headphones. How do I get the mic to work??
On the back of the computer or front there is a GREEN Jack for the earphones and a PINK Jack for the Mike. If you have the speakers plugged into the GREEN jack you will have to pull it out and incert the headphone jack into the GREEN color jack and it should work.
Hope this is of some help. Bud
Jan 12, 2010 | Logitech QuickCam Chat Personal Web Camera
Headset symbol displayed with no headset plugged in
i'm getting so so tired of these ridiculous problems. you shouldn't own a phone if you can't solve these sorts of prblems yourself. pathetic!
Feb 12, 2009 | Nokia N73 Cellular Phone
Nokia 7370 Cellular Phone Logo
301 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
