Hi if the phone comes on press *#06# this will give you the code if not then its on back of phone and looks like 643722/12/54325 its usually about 15 numbers long plus or minus 1 number depending on make of phone. let me know if you need further assistance ok
When the page loads, select, free remote master code
In the area provided for imei/serial number, insert the serial/imei number of the phone.
Click on generate.
Once done, a number will be generated, that's the master code for the phone, copy and keep the number. When ever that particular phone is locked with security code and you want to unlock it, even though you don't know the phone's security code, just enter that number, i.e. Master code and it'll be unlocked!
Click on generate.
I didn't get your question. you didn't add your network provider. did u mean unlock code? if its unlock code take this: Your Suggested unlock code is : #pw+242545366006651+5# Type: DCT4 Nokia Model: 6600 IMEI: 353399046540526 ASIC Type: 5 Box serial: 032811
You can get the unlock code and instructions through online . only you should give your IMEI number and get the unlock code for your mobile. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
You can take the help through bellow link. http://unlock-zone.com/ website for unlocking your mobile .There are so many website for unlock mobile, but it is recomended by mobile forums.This side is really perfect.Only you need to wait few minutes.. Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because, this is the free side and I can get the chance, to help people like you . Thanks for using fixya .
For Nokia phone - try this WEB site too :- www.unlock-free.com/nokia-master 6)The IMEI number is unique the each mobile phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
if your phone is active, its usually the last 4 digits of your phone number. You can also try 1234, or 0000. If you changed the code, you will have to contact customer service. FYI You should NEVER give out your imei/esn(serial) number of your phone. Good luck
IMEI unlocking is the easiest way to unlock your phone. Your IMEI is a
unique 15 digit number that is used to identify your phone. You can
display your IMEI by pressing *#06# on your phone’s keypad. The IMEI is
also printed on the back of your phone, usually printed on a label
underneath the battery.
If it's a gsm phone, you can get imei unlock codes here: http://gsmunlocklabs.com
