Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher FDB435FRF3
The water does not drain out. What can I do ?
There is a small part under that has a small motor with a blade on the other end that sounds like the bushing is going, it rumbles and buzzes when turning.
Paul
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like theres somthin stuck in the drain motor, you can take it off and check for obstruction. bebareful though if its full of water your gonna get wet, and that water probably pretty nasty
Posted on Mar 13, 2008
Frigidare fdb1500lfco
Good Morning Kristen - You may try to reset the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the dishwasher back on. If this proves to be ineffective, then the unit may possibly being experiencing a communication issue with the control panel, wiring failure, drain motor/pump or water valve. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 28, 2013 | Frigidaire 24 in. FDBB840DC Stainless...
Dishwasher draining / emptying of water
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 27, 2008 | Frigidaire Dishwashers
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher will not drain..
I would check for an obstruction in the drain line. Under your sink, find where the drain hose connects to the main drain. Remove the drain hose, and stick a small screw driver into the spout of the main drain and see if there is any food build up.
Apr 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
PUMP NOISE
Well some small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris. Post comments if further you have the same problem.......
Good Luck!!
Mar 26, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher PLD2854rdc2 Water seems to pool up at the bottom an never completely drain out. I have cleaned out any accumulated food but doesn't seem to drain.
you are supposed to have a small amnt left in bottom about 1-2 inches it keeps the motor seal wet so it will not dry out and create a leak that could cause more damage
Dec 25, 2009 | Frigidaire PLD3460REC Dishwasher
My Frigidaire dishwasher doesn't drain completely after it cycles through completely. This is a new dishwasher just installed it a couple days ago.
Drain line/air gap
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Timer
Sep 03, 2009 | Frigidaire Dishwashers
Dishwasher not draining
either your drain is cloggee where it connects under the sink, or perhaps htered something in the drain motor itself ( its aseperate motor under the dishwasher, you can remove and inspect. turn off power first, live wires!
Mar 01, 2009 | Frigidaire Dishwashers
Frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Dec 22, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
155 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
