Question about Garmin GPS
Nuvi 760 Diagnostic menu
Are the diagnostic menus (accessed from the battery icon)
read only or can you change various parameters such as FM
power output? On one page there is a option to start and
stop playing a selectable phrase but it does not appear to work. Garmin does not comment on this type of question.
This is regarding the Nuvi 760.
SOURCE:
  • 3422 Answers
SOURCE: I have a Garmin 760
HI,
PLease CLICK HERE
to subscribe for that feature..
Posted on Jul 15, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 660 internal speakers
Please see this article I wrote on this problem.
http://www.fixya.com/support/r1094734-no_sound_or_garbled_sound_nuvi_series
- Jim
Posted on Oct 31, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
SOURCE: Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: no sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Posted on Jan 07, 2009
If I found a garmin nuvi gps it got a locked on it how can I reset it or something
Most GPS navigation devices from Garmin has a reset function which allows user to access a Maintenance Mode screen with system information, diagnostic details or perform the reset function to restore Garmin Nuvi or other series unit to its original default factory settings.
Depending on which model of Garmin GPS unit you're using, the following routine can reset the Garmin device to original factory loaded settings, or bring up the Maintenance Mode with access to System Information and View Diagnostics screen, where users can see various logs, and of course, clear all user data (reset to factory defaults) or clear Waypoints.
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit. In fact, there is a video demo by user of Garmin Nuvi 360 on how to perform the hidden reset function.
Hope helps. (remember to rate and comment this answer).
May 19, 2011 | Garmin nuvi 255W GPS Receiver
Pls give an service mode of tcl-21276p tnx
Try this :
simultaneously press "DISPLAY" button on remote handset and Volume- button on the front
panel of television receiver for 6 to 8 seconds to get the various service menus.
• To access any parameter , use Up/Dn keys of Program/Channel
• To change value of any Parameter, use +/- keys of Volume
• To exit POWER switch off the set
Good luck
Mar 23, 2011 | Televison & Video
My garmin nuvi 765T has no volume coming out from internal speaker but it comes from handfree, how to solve this problem? plzz help me
Power unit on
Press Volume Icon..... If there is a check mark on mute remove it
if not
Press FM Trans
uncheck Enable FM Transmitter
Love my Nuvi760
Oct 21, 2010 | Garmin Nuvi 760 Car GPS Receiver
Touch screen doesn't work sometimes and can't be recalibrated
In that case, the touch screen is faulty and must be replaced; it's a fairly common fault and your faulty screen cannot be repaired. If you search YouTube for "Nuvi 760 battery replacement" you'll see how to dismantle your machine.
The screen is not hugely expensive and not difficult to fit, and as you obviously realise you'll need to enter the diagnostic menu after fitting to recalibrate the screen (for those reading this who are unfamiliar with this, press and hold the battery icon to access the diagnostic menus).
Although the screen isn't that expensive, consider whether to replace the battery at the same time as it's probably seen better days. But when you add the cost of the screen and the battery then if the maps on your machine are out of date then it's going to make more economic sense to buy a complete new machine.
Jul 27, 2010 | Garmin Nuvi 760 Car GPS Receiver
I lost all voice prompts on my Garmin Nuvi 760. If I use the FM band, it works, and the volume works for keystrokes. Is there a fix for this?
you will just need to de activate the FM transmitter to do that press the volume button at the bottom right hand corner of the main menu and uncheck the box that says something about the FM transmitter
Jul 09, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I am not receiving any sound form my nuvi 760
Have you checked the sound level, or the possiblity that it is muted?
this is common with the 760 since everything is accessed via the touchscreen menu
Mar 27, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 not in English
Hi, from the "Where To" / "View Map" screen, select the tools (spanner icon), then Settings (spanner icon again) then Language (Mouth icon).
There should be 3 options, the lower left is the Keyboard; select this then scroll to British English. The upper icon is the Voice, choose a suitable one (if it says (TTS) it will read out street names as ir gives directions), the top-right option is Text, again choose British English.
Jan 02, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Aug 10, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Battery Icon.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
See also battery_repair.
Jul 02, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
598 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
