I need to know the max memory for my laptop.model psaa2u01x019, satellite a105. also where to get the parts
    Scholar:
  • 99 Answers
The maximum amount of RAM that your laptop can support is 2GB. you can get it from most places that sell computer components, just look for DDR2 SODIMMs or DDR2 laptop memory.
Posted on Mar 13, 2008
    Sergeant:
  • 349 Answers
If you paste, your make & model of your laptop into a search engine,ie (Google) it will show you many sites that have information on your laptop and places where you may purchase items for it .one example is http://www.paulschiro.com/laptop.pdf
gives you the spec's of your machine.
good luck
Terry
SOURCE:
Where do I find the part number for the motherboard
Look near the memory slots. You will see labels. Also look all inside the board for labels. Write down the numbers you see on your motherboard. Then get on Ebay and look for motherboards for your laptop. The board on ebay will have model numbers on them, look for a number that matches what you wrote down.
Below is a link to the motherboards I found on eBay for Toshiba Satellite A100.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+A100+motherboard&_sacat=See-All-Categories
Below is a link for the A105 motherboards
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+A105+motherboard&_sacat=0&_odkw=Toshiba+Satellite+A100+motherboard&_osacat=0&_from=R40
May 13, 2012 | Toshiba Satellite A100 A105 Series Laptop...
Toshiba Satellite A105-S4184 T 2250 1.73 ghz. I am a DJ. What is the Max of memory can I have on it? Can this system run the Numark NS7? Glass Dee http://www.go-djs.com
That is interesting, that model doesn't appear to exist. However, try checking out your manual or go to
http://eu.computers.toshiba-europe.com/innovation/home/
You will find all the information you require there.
Hope that helps.
Nov 13, 2010 | Toshiba Satellite A105-s4184 Notebook
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
What kind of memory can I put in my toshiba satellite a105-s1712
DDR II SDRAM.
You'd have to look at your manual to find out maximum memory.
Mark
Mar 28, 2009 | Toshiba Satellite A105-S1712 Notebook
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
Can't upgrade memory past 1gb when max is 2gb
I have the same issue with my laptop. I have not been able to get the laptop to accept 2gb of memory yet, but I did find something that works. If you put your 512mb memory that works in the laptop and then add a 1gb stick in the second slot it works. Or at least it did for me. It's better than nothing. I am still trying to figure out how to get it up to the 2gb max. Will add a solution if I figure it out.
Feb 08, 2009 | Toshiba Satellite A105-S1712 Notebook
NETWORK DRIVERS
network driver for satellite a80 129
and motherboard driver either
Jul 18, 2008 | Toshiba Satellite A105 Notebook
Can I add another 512MB of memory to my A105 satellite toshiba
i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
Nov 22, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
