How can I recover CD-Writer that was accidently removed from computer?
HP Pavilion 7955 CD-Writer cd16e accidently removed from computer
  • flores_ester Mar 13, 2008
    Thank you for your help but I'm still do not understand. You mentioned to go into a control panel and add new hardware what I can not enter "No, I have not added the hardward yet" because I do not any hardware to add.
  • 40 Answers
Go to control panel and add new hardware. If the computer does not see it, check the cables and then consider purchasing a new cdr/rw
srich
Posted on Mar 13, 2008
  • Anonymous Mar 13, 2008
    after you click control panel and add new hardware, the computer should look for your device if you so tell it.
    srich
SOURCE:
Green light is on pwr suppy. +12 and +5 volts a little low. Power_On volts goes from +4.8 to 0 at startup on 24 pin pwr connector.computer beeps 3 sec.off and on till turned off. HP Pavilion 7955
Pavilion 7955 , 1997 year.a very old Pentium 4 , Desktop the PSU is bad.
its only worth for the trash, any P4 puter, it's junk .
4.75vdc is low as is allowed.
did you jumper test the PSU first.
the MOBO and thE PSU can both turn it off.
so can shorted modules, remove all not needed things first.
dvd , and all hdd .
all usb.
all memory but 1 stick in bank 0
even remove video card. if it has one, must now turn on.
unplug the 24pin, and place the jumper seen here
the PSU must run, if not the PSU IS TOAST.
if it does run we top the mobo unloading, of all things that can short out..
http://www.pcdied.com/power.html#Jumper
Oct 21, 2017 | HP Computers & Internet
Hp Pavilion 7955 won't recognize any
if it does'nt recognize any keyboard using usb or ps2 ports that means that you need to replace the motherboard or the system board of your desktop. var geo_Partner = 'd420811f-d70c-453a-bc20-eaee3c451b98'; var geo_isCG = true;
May 11, 2011 | HP Computers & Internet
I recently bought a used TEAC CDWE552-GB CD Burner for my old computer. I received the power cord and cable to power it up but not the cables to attach it to my computer ( HP Pavilion 4550Z ). The ports on...
Unfortunately, I don't think you can use this CD writer on the HP Pavilion 4550Z directly. The CDWE552-G is an external USB device. The HP Pavilion 4550Z doesn't have any USB ports.
There are two options that I think you could consider. 1) Get a USB card to insert into the micro-tower. It's currently easier to find PCI USB 2.0 cards, see https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100168119%20600022008 for some examples. Before purchasing, check to make sure the card is compatible with the OS on the HP Pavilion 4550Z. It started with Windows 98. You will have to remove the Fax/modem to use that slot. (An ISA card might work but I haven't seen an ISA bus USB card in years.)
2) Take the CD writer out of the external case. The CDWE552 should use an IDE cable; just swap this CD writer for the one in the micro-tower. The HP Pavilion 4550Z should have the appropriate cables inside the tower. The original CD reader specifications indicate it was an IDE device.
I hope this helps.
Nov 29, 2017 | Computers & Internet
Dvd writer & cd writer tray lights up but will not open on HP pavillion model no t760 uk
Go into My Computer and right click your DVD writer/CD Drive and click eject.
Mar 05, 2011 | HP Pavilion a1700n PC Desktop
Black screen bootmgr is missing cntrl alt delete to restart win xp hp pavilion 7955
  1. Boot your computer with the Windows XP CD.
  2. On the "Windows XP Professional Setup" menu, select "R" for Recovery Console.
  3. You will be prompted to select the Windows installation to repair, usually option 1.
  4. Enter the Administrator password, followed by enter.
  5. At the command-prompt, type "fixboot" (excluding the quotation marks) and press enter.
  6. Press Y and enter to confirm.
  7. Remove the XP CD when complete, and Restart the PC.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 24, 2011 | Computers & Internet
I am looking for a hp lightscribe dvd supermulti drive/cd writer that is compatable with a hp pavilion a720n desk top computer and all so a dvd/cd rom combo that is compatable with ...
Any brand-new CD/DVD reader/writer with LightScribe *WILL* be compatible with your HP.
Check whether your "power" and "data" cables are the "old" style (white power connector and a 80-pin ribbon-cable) or the "new" style (thin SATA cables), before you buy a writer with the "wrong" (PATA versus SATA) interface.
Sep 26, 2010 | HP Pavilion A720N PC Desktop
Computer won't start The voltage switch on the power supply was accidently changed to 230. Is it fixable
Most likely not, the power source is dead, replace it. It's a standard ATX source, any 400W one you can buy from all IT shop will do.
Apr 25, 2010 | HP Pavilion 7955 PC Desktop
Hp cd-writer Not Working
Depending on what HP computer/cd-writer it is the type of disc you are using may not be supported.
Older cd-writers often had a specific type they could write to, CD -r / CD +r.
You should try to find out what kind of discs are supported by your cd-writer. This CAN be located in text on the front of the cd-writer.
Dec 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP DVD WRITER DVD 200i
Well.. i would suggest that you take direct telephonic help from hp customer care... they'll help u at every software related need and if u already have the cd in the cd packs provided with the pc... 'cause this problem will be best known to hp people.. :)
Apr 13, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Open Questions:
Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}
Oct 16, 2019 | AVG Computers & Internet
Computers & Internet Logo
44 people viewed this question
Ekse
Alun Cox
