Question about Akai PT46DL10 46" HDTV-Ready Television
Need new Jl amp
Were can i buy a new J lamp for this model?
  • wilk32 Oct 27, 2008
    Go to deadlamp.com that is where i got my from they have all models it came to my house in 1 day.
I found a source for all lamps it had the lamp for akai pt46dl10 46 in HDTV-READY IT'S CALL DEADLAMP.COM. GOOD LUCK
Posted on Apr 03, 2008
Dlp Lamp source does not have the bulb for the J model. I just talked to them.
Posted on Apr 02, 2008
DLP LAMP SOURCE. PO BOX 503882 SAN DIEGO CA.92150
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
Amplifier not working
is youre radio factory or out of market..well if it is factory youre converter is not workink buy a new one,, but if you have a aftermarket' the rca outputs are out on the radio... the best thing is return it and try it again if it does the same thing you will pretty much know what it will be...hopefully i hope is just a difected amp..instead of youre aftermarket radio if you do have one..
Feb 21, 2010 | Jl Audio HD750/1 Car Amp
I have 2 jl audio 13w7 and 2 mono 1000/1 amps one for each woffer, one of the woffers blow. this set up is in a ported box. I was just driving to work bumping it like around 25 and the speaker startd to...
check your bass leval on your amp and make sure it is the same leval as your other amp. Also you w7 can be repaired they just change the coil. cheeper than buying a new one.
Sep 05, 2009 | Jl Audio 13W7 Car Subwoofer
Amp smokes but still works transitor looking thing is melted?????
954-443-1100 is the service department, sounds to me like your amp is slowly but surely frying itself. i am not sure putting a new transistor in it will help anything but you can try. There only around 15 dollars
Aug 23, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Mar 18, 2009 | Jl Audio E1200 Car Audio Amplifier
Jl audio 500/1 problem
Usually all amps spark a little when hooked up again after a while of no use. this happen cause there are many little capacitors inside to keep the amp running when hitting long bass notes. I think the reason you have been having problem after replacing the transistors is because there not the rite model number or maybe the polarity. You mite have to call jl and ask them if they have any in stock or google the model number of the transistor and buy them and replace them and see if it work. if it doesnt work then it mite be something else inside.
Jan 16, 2009 | Jl Audio 500/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Amp cell went bad!!!
You may be able to find a local shop that can repair it. If you want to send it to JL for service, you'll have to go through an authorized dealer.
Service FAQs
Dec 04, 2007 | Jl Audio 300/4 Car Audio Amplifier
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
My JL audio 1000/1 amp does not work
Best bet is to send it back to JL, they do not sell the PCB with all of the components loaded on it. Most likely the transistors in the power supply have fried. Open it up and see if you can find any physical damage. Google the part numbers of the bad parts, and you should be able to fix it relatively easily. www.digikey.com is a great place for parts. Read this for more testing procedure: http://www.bcae1.com/ampfail.htm The whole site is wonderful, really.
Jun 30, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Akai PT46DL10 46" HDTV-Ready Television Logo
109 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
