After cleaning my carbs.. just the float chamber and carb cleaner in areas I could reach by removing the Vacuum chamber cover and jet, I have fuel pouring from one of the air vent tubes. What Did I do wrong? (other than trying to clean all those carbs)
Well, a couple things may be wrong.
1) debris could be lodged under the needle valve. Remove the float by gently slideing the float pin out, the needle will either slide out with the float or remain in the seat and a pair of needle nose pliers will help to retreave it. clean the seat and inspect the needle valve for damage.
*note that even the smalles debris can keep the needle from seating so take care during reassembly*
2)depending on the type of carb cleaner used, and the exact type of needle valve in your carbs, the needle valves may have been dammaged during the cleaning. Some carb cleaners can "eat" neoprene or rubber components in carbs. It is always best to fully disassemble them before cleaning, if you are not confident in your ability, have a pro do it for you.
The solution for this is to remove the needle valve as above, and inspect the needle and float for damage. **If in doubt replace the needle valve**
Good luck.
