Question about Maytag SAV5710 Top Load Washer
Maytag Performa Washer won't spin. Bought new bearing kit. Removed pulley and thrust bearing. New bearing is different from the one I took off. It's encapsulated with spacer. Not enough room to put it all back together. I can push brake up by prying a ***** driver between brake and bottom of support panel but this takes some force, Stuck on what to do next.
  • 3 more comments
  • Ratray
    Ratray Mar 13, 2008
    Finally got it on. Tight fit. Couldn't line up adjustment marks because it wants a thinner bearing and there isn't one thinner then the one I put on. Close though. Put it back together and tried it. Spins again! Tried a wash, works great except now it makes a kind of grinding noise on the clockwise agitator stroke!
  • Anonymous Mar 15, 2014
    i have a maytag mavt546eww we replaced the Thumb bearing and pulley and the brake still dont release
  • Anonymous Mar 16, 2014
    maytag mavt546eww replaced pulley and thrust bearing now there not enough shaft to put flat washers on to adjust.
    after putting on new thrust bearing kit both flat washers are still to thick for cam.
  • Anonymous Mar 30, 2014
    Whirlpool washer putting on new brake cam lever no room to put the c-clip back on need help
    President:
  • Maytag Master
  • 2,651 Answers
Thinkin your installng a new thrust bearing kit?? new one is different(actually better not as many washers). Laying this unit on its back or even side will alleviate some of that tension your experiencing. My problem is always trying to fit the E-clip back on after installing the pulley. Turnin the pulley i beleive clockwise will engage the brake and give you a little more play in the shaft. i usually get that clip on slightly and then grab and squeeze on with pliers
Posted on Mar 13, 2008
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
After the final spin cycle, my clothes are always soaking wet. Can I fix this problem on my own?
Google "kit for bottom of washer not spinning", you may get by with a thrust bearing kit and maybe a new belt(belt may be ok) You do not need any special tools,and kit comes with instructions. Kit is bottom pulley some plastic gears(not best description) above pulley and some shims(washers) You will need to read up a little to install correct washer to get right lift from pulley and gears to release brake for spin,
good luck
Mar 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag performa washer will not agitate or go into the spin cycle. It makes a loud noise instead
From what you're describing I suspect the thrust bearing needs replaced. The thrust bearing is what releases the brakes. You will not be able to rotate the basket manually with the brakes set. I recommend replacing the thrust bearing kit part number
Jan 10, 2011 | Maytag Washing Machines
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Washer making rattle noise during wash and spin cycle
I would agree with that diagnosis. That is a symptom of a worn thrust bearing for sure and it is a quite common occurrence on your style of washer.
I wouldn't rule out debris in the drain pump as another possibility as well though, i.e. small stones, jewelry, etc. You may want to rule out that possibility before throwing money at a pulley & thrust bearing kit ( it is actually a "transmission pulley kit" which comes with a new thrust bearing as well ). part # 12002213 and retails for about $40-$50 see photo's below.
Hope that answer's your question. Let me know if I can assist you further and thank's for visiting "fixya" for your repair inquiry. Please take a second and rate this info I provided for you here.
Good luck.
macmarkus :)
Mar 16, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 - Washer agitates during wash. on spin cycle motor runs and belt is fine, but drun does not spin. Water drains. Why does it not spin?
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Maytag PAV2300 Top Load Washer
My matag performa makes isn't spinning or draining the water
im sorry to say the problem you have is in the transmition a new transmition thrust bearing and seal kit would be needed to repair this properly parts alone you are looking at 250 - 300 dollars
Jan 19, 2009 | Maytag Performa PAV2200
Clutch on a maytag
no this machine has a thrust bearing not a clutch if the machine is not spinning well you need to replace the thrust bearing kit it come with a new drive pulley
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Washer won't spin or agitate
jesus crist remember all the work that machine did for your family and forbiden it, it sound to me to be the transmision, but wait for catriver, gona tell you somes tips, put your hammer in the closset by now..good luck
Aug 06, 2006 | Maytag Performa PAV2200
Maytag SAV5710 Top Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
