Question about Kenmore 41389 Electric Double Oven
F10 code I went to use my oven for the first time and shortly after it preheated and I put my food in, it started beeping and the F10 code appeared. Does anyone know what that means?
  • Anonymous Mar 18, 2008
    F10 on my oven
Actually I gave up and called Sears - its an electrical surge.
Posted on Mar 14, 2008
  • 796 Answers
Actually F-10 was not listed on the error code list,
do you see any other malfunctions in the display???
Posted on Mar 13, 2008
SOURCE:
What does code f10 mean?
get a small oven thermometer and put it inside the over to check what temp it goes off at .many times it is a bad thermocouple .
Sep 25, 2015 | Kenmore Ovens
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 13, 2011 | Maytag Ovens
We have recently bought a Casera 28L Microwave/Convection Oven. the Instruction Manual refers to Oreheating but gives no instructions on the procedure to turn it on. Can you help us please? Ken &...
Hi Guys,
What model have you got? I have one that I have owned for well over a year now with absolutely no problems. In fact I would have to say for the $119 I paid for it, it has been the bargain of the century so far.
My model is CAS048 and to preheat it is very simple. You set the press the convection oven button to set the temp you want (i.e 180 deg) and push start. The oven will operate until it has warmed up at which time it will beep 3 times. Open the door and put your food in and set the time you wish it to cook and you are away!
P.S, mine will shut off automatically after a few minutes of reaching it's set temperature if I don't open the door and set the timer on it, so it pays to have your food ready or close to ready when you set it to preheat as it warms up quite fast.
Apr 07, 2011 | Ovens
When preheating the oven it beeps constantly and F10 appears where the temperature should be....what do I do?
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Feb 26, 2011 | Kenmore Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
No Sound on frigidaire black smooth top stove/oven
Check in the manual, sometimes the alarms can be disabled.
Please reply the complete model number to see if that ability exists, or what the P/N is of the timer.
Feb 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Apr 19, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 41389 Electric Double Oven Logo
347 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
