Question about iLO DVDRH04 DVD Recorder
Replacing dvd player/burner on iLo DVDRH04 DVD Recorder
My dvd player/burner quit working on this unit a couple of years ago. I'm interested in trying to replace it. Can you suggest a burner/player that is compatible? One that I could buy at somewhere like TigerDirect?
  • Pakkbakker May 10, 2008
    Not the same problem as I have. Thanks anyway.
  • Pakkbakker Feb 03, 2009
    Hey Fabioteran. Thanks for the help. This may be my best chance to get it working. Can you give me the model of the Samsung DVDRW burner that you're using? Thanks again, Pakkbakker
I HAD THE SAME PROBLEM. I ALSO HAVE THE ILO DVDRHD04 AND I'VE BEEN PREETY HAPPY WITH IT, BUT THE DVD RECORDER WORKED FOR ABOUT A MONTH AND THEN IT WOULD NOT RECORD. I TRIED EVERY SINGLE BRAND OF DVD-RW DISC THINKING THAT IT WAS DISC-RELATED BUT NONE WORKED, IT WOULD ONLY PLAY THE DVD'S. ONE DAY I DECIDED TO OPEN THE CASE TO SEE IF THE DVD NEEDED CLEANING AND NOTICED THAT IT HAD REGULAR IDE CONNECTIONS, JUST LIKE A PC. I DECIDED TO TRY A SAMSUNG DVD BURNER I HAD TO SEE IF IT WOULD WORK. MUCH TO MY SURPRISE, THE DVD PLAYER WORKED BEAUTIFULLY. I WAS ABLE TO RECORD INTO IT, INCLUDING IN TIMER MODE, AND PLAY ALL TYPES OF DISKS. ALL YOU NEED IS AN EXTERNAL DVDRW(I HAD A SAMSUNG AND IT WORKED PERFECTLY), ALONG WITH AN IDE CABLE(IT SHOULD COME WITH THE BURNER). I OPENED THE CASE AND PLUGGED THE IDE CABLE TO THE BOARD INSIDE THE DVR AND PLACED THE DVDRW ON TOP OF THE UNIT. YOU ALSO NEED A INTERNAL COMPUTER POWER CABLE THAT WILL REACH FROM INSIDE THE UNIT TO WHERE YOU PLACE THE DVDRW. THIS IS NECESSARY BECAUSE THE CABLE INSIDE IS FOR THE BUILT-IN UNIT AND IT'S TOO SHORT.
IF YOU TRY THE ABOVE WITH THE SAMSUNG DVDRW BURNER, YOU SHOULD BE ABLE TO FIX YOUR PROBLEM FOR ABOUT $40. GOOD LUCK!!
Posted on Oct 01, 2008
I Have ILO DVRHD04 and my front buttons sto to work when i use the remote works ok... when the unit is of I turn on from the front paner works ok try to turn off from the front buttons is not work and the lite in the front go crazy only when i pres stop & play button and on fo button... what is the problem... The remote work ok play stop edit or recodring
Posted on May 09, 2008
ILO DVDRH04 DVD Recorder
to the rescue...here we come..now what sort of software...you were using
May 25, 2008 | iLO DVDRH04 DVD Recorder
ILO DVDRHD04 won't copy dvds. Says
The 04 version of this player only uses DVD +R or +RW it will not reconize -R or -RW make sure you are using the approved DVD media for this unit
Jan 31, 2010 | iLO DVDRH04 DVD Recorder
Burner on DVD Recorder; it neither records nor plays DVDs
through experience, bring to a tech nearest you.its either the lens or the mainboard or mpeg is faulty.
May 27, 2009 | iLO DVDRH04 DVD Recorder
NO SOUND AFTER COPYING TO DVD+
try runn8ing a digatal cable insted of rca
Dec 07, 2008 | iLO DVDRH04 DVD Recorder
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
DVD recorder
If you are still wondering, Try here
It will tell you how.
Oct 25, 2007 | iLO DVDRH04 DVD Recorder
Mr ilo dvd R04 recorder is locked at the hello screen!!!!
The unit is not finishing the start up diagnostic. This could be forseveral reasons. The most common problem with the Ilo04 is power supply. On the power supply board check the two big capacitors to see if they are swollen or leaking. If so then change them and try that.
Jul 13, 2007 | iLO DVDRH04 DVD Recorder
Ilo-DVDR04 recorder problems
The laser is either dirty or is starting to go.These lasers in this model usually only last two years.To clean but a commercial disc cleaner philips or Maxell work good in this model.Put a drop of rubbing alcohol on brushes this helps clean laser.I would do this every 15 hours of use .The best way to clean laser is to rub gently with a Qtip soaked in rubbing alcohol but this requires some technical knowledge for you have to open burner.If you attempt this make certain electrical plug is pulled lasers cause nasty burns.
If laser is going you can replace the burner/loader unit,this model uses a 411s or 451s Liteon burner.The 401s and 813s will also work without problem.
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
Ilo dvd burner
Go online to update the firmware. If that does not work call the company to find out if they want you to ship it to them to correct the problem. There may be a recall on the unit. You do have a firmware problem in most cases. The other problem is that you may have to only use the same disk brand as the unit to get the system to work.
Apr 17, 2007 | iLO DVDRH04 DVD Recorder
iLO DVDRH04 DVD Recorder Logo
413 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
