Red and orange screen
Someone gave us a 60 inch rear projection TV. The picture comes in, but the color is off quite badly. Everything appears red or orange, and there is very little blue or green definition. I have tried to adjust all of the settings for the picture via the remote, but obviously that is not the problem. I have read several postings with similar problems, but all have different answers.
Could someone tell me what may be causing this issue, and an approximate cost for repairs?
Thanks much!
  • 2 more comments
  • tahiti petey Mar 13, 2008
    orange red screen with horizontal lines?
  • Anonymous Mar 24, 2008
    first I had fine red lines, now I have a orange screen.
  • Rhonda Ford Apr 18, 2008
    My husband bought this tv second hand and every channel the picture is red or yellow or orange. We have tried to adjust it manuelly but nothing has work.
    Please let us know what the problem is and how much to fix?
    Thanks Rhonda
  • mwstock Mar 02, 2009
    what are the STK's?
Picture on my Samsung would flash especially bright colors - now those colors have vanished and there are only dull greens, browns and blacks
Posted on Nov 07, 2008
It is the STK's in the rear that need replaced usually about 300 to do the job, call a jvc familiar reapair center, They say they always have them in stock
Posted on Apr 03, 2008
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
60 inch maganavox rear projection tv blue color almost gone if it is a bulb where can I buy one
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
60 inch has no red
Hi, you`ll need a tv tech for that one, either no red out from rgb chip, bad driver ic, etc. none of these repairs can be done without special tools, video-tek
Jun 29, 2009 | Philips 60P8342 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60P8342 picture blurry with orange tint
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
Philips 9P6040C 60 in. Rear projection
Here are some of the most common symptoms.
  • Screen looks 3D
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
