Ecoquest Flair Air Purifier Logo
Teri Paris Posted on Mar 25, 2010
I have a flair ecoquest air the neon light is not goin on
I have a flair ecoquest air purifier the neon light is not going on but the machine still appears to be working should I be concerned
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 29, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
7985
Points
18
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint..............the same high voltage transformer is used in the bug zappers.
indiandoctor
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Apr 03, 2010
indiandoctor
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
8386
Points
29
No but your uv ligth its burn out
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Ecoquest freshair - inside wireing
Black = phase white = Neutral , Strip yellow/green =ground
1helpful
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Light wont come on. Purifier wont work
When the high voltage transformer is working right, it will make the neon bulb glow.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Ecoquest flair fan replacement. Cannot read the model # on fan.
I can help you get a replacement fan for your flair if you still have not found one. You can reach me at [email protected].
1helpful
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
Flair
You need to order two ceramic plates and a lint filter. The lint filter is the one that goes on the back. The two glass plates are what ionizes the air. They do not make them from glass anymore. You will need to go to the ecoquest website nd order the parts. It will run you right about $75. Ecoquest bought Flair out a few years ago. Hope it helps.
http://www.airpurifierrepair.com/index.aspx?id=38&gclid=CIuXr5H1mJYCFSCcnAod_GOy7A
Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Flair air purifier
You can download the users manual and troubleshooting guides from the Ecoquest web site.
http://www.ecoquestintl.com/customers/owners_manuals/index_home.asp
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
