Brightening my computer screen
I have a Toshiba M35-S320 please tell me how to brighten my monitor screen?
    Problem Solver:
  • 11 Answers
Push and hold the Fn button and for decrease of brightnes push F7 for increase push F6 . So Fn+F7 dark: Fn+F6 bright.
Arsim
Posted on Mar 13, 2008
How to generate Response Code for challenge code for bios on m35-s320
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen user Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 23, 2012 | Toshiba Satellite M35-S320 Notebook
My screen brightness its lees
Then brighten it. You brighten it by Holding Down either FN, CTRL or DEL key + Hit the corresponding key for brightening the display.
For example on my computer I press and hold the FN Function key while I hit the UP Arrow key to brighten the screen.
The brighten/darken keys normally have the icon of a circle with sprockets around it like the sun or it looks like a washer that goes between a screw.
Mar 23, 2012 | Toshiba Qosmio G45-AV690 17" Laptop PC...
Fn F6 and F7 stopped working. Can't dim/brighten screen
First, try to test the functionality of the Fn key by using it to alter another setting on your laptop. If it doesn't, you'll need to go to BIOS and enable the Keyboard Function option (or alike, depending on your BIOS version).
If the Fn key does work, then try to see if F6 and F7 function at all. For example, if you're using Firefox, the F6 key should highlight the entire URL of the website you're visiting. F7 brings up a "Caret Browsing"dialog box. If both keys function well, then you may want to reinstall the drivers of your graphics card. If nothing happens after the update, and if you use Vista, then go to Start, and right-click on the Computer label. From the popup menu select Manage, and in the new window go to the last listing, where you'll find a sub-entry labeled Services. Click on it, and from the list on the right, look for a service that's called Keyboard shortcuts or alike (sorry I don't remember exactly how it's labeled as I dont use Vista). Double-click this Keyboard service, and from the new windows see if it's started, and if it's set to Automatic run each time Windows loads. Then restart Windows and hopefully your LCD will dimm/brighten.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Dec 21, 2010 | Toshiba Satellite M35-S320 Notebook
How do i bypass the bios password on a toshiba satelite m35-s320
your password is toshiba.. enter that and then you may change it to your desired one..
Aug 21, 2010 | Toshiba Satellite M35-S320 Notebook
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
Looking for Toshiba HDD for M35-S320
you can buy the HDD in your laptop at computer shop, but check first if it is SATA or IDE...under your laptop,there are 2 screws remove that and remove the HDD and check what type of HDD you have..here is the idea, with 40pin its indicate IDE with small flat connector its SATA..remove and check and go to computer shop,they will ask you also how many GB you want...80,120,160 whatsover..buy and replace the HDD.
Nov 03, 2008 | Toshiba Satellite M35-S320 Notebook
Brighten my computer
1.Check G2 Screen Cathode Voltage.
2.check from G2 cathode to LOT G2 supply pin It's related Low value &High value resisters.
3. replace G2 PF
Sep 22, 2008 | LG Flatron F900P 19" CRT Monitor
Computers & Internet Logo
1,424 people viewed this question
David Payne
David Payne
