Question about Vacuums
Need help with my vacuum
I have a small vacuum that is bag-less, and I need to know if I can wash the filter or if I need to get a new one and where can I get a new filter at and what kind of filter can I get? Where do I go to get a new filter and what is the name of the filter that I need to get?
  • tds82905 Mar 14, 2008
    I don't know if this will help you to determine if I can wash the filter or not but the model number is DB9191-B VACUUM CLEANER 31CX E255344 CLEAN BOOM ELECTRIC CO LTD MANUFACTURE DATE 0407. Please let me know if I can wash the filter or if I need to get a new one. If I need to get a new one where can I purchase it at and what size do I need to get?
    Thank you,
    Daphne Sims
    Thank you that helps a lot.
You can wash the foam filters but make sure they are dry before putting them back. I have just ordered spare filters online from www.espares.co.uk You can search for your vacuum cleaner model number to find the correct filters. Alternatively, you can ask them.
On my Hoover dust magnet cyclone cylinder machine I found another filter beneath the plastic box that collects the dirt & dust. I removed it and washed that too. I didn't know there was one there until I read it somewhere. You shouldn't use soapy water to wash it, just plain, cold water. It has made a big difference to the vac's performance.
Posted on Mar 26, 2012
    President:
  • 1,673 Answers
You didn't state brand and model number. Some of these filters can be washed, make sure it is dry before putting it back on. If it is a year or more old, then replace it. Call around to your local repair shops to see they would have a replacement filter.
Posted on Mar 13, 2008
  • Lauren Junge
    Lauren Junge Mar 14, 2008
    Guess I haven't heard of your brand, But you could take it to some one that has an air hose and blow it out. Check in your user manual and see what it says about replacing filters to see if they will cover for a new one. You should have a years warranty on this. It may also tell you about cleaning the filter. They may be available at one of your local area repair shops. It maybe washable, but blowing it out will work just as well and then you don't have to worry about if water will damage it.
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 | Vacuums
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
How do I change twin filters?
Try washing them as a n assymbley. Let tham dry for a long time and see what happens. They can be changed but not usually needed.
Jan 23, 2016 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Why won't my hoover u6434 900 turn on?
Hello! The vacuum has a thermal protector sensor that will automatically shut off the vacuum when it is overheated. The vacuum should turn back on once it has cooled down. This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are steps you may follow to check your vacuum for blockages.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Hope this helps!
Jun 14, 2014 | Hoover U6434-900 Bagged Upright Vacuum
My Hoover Tempo has almost no suction
Most vacuum cleaners have more than one filter (even bag-less vacuums sometimes). I have found that after being used a while the motor filter blocks up. I just remove it and use another vacuum to clean it out. Depending on the material you may be able to wash it in warm water or if you can get your hands on a new one just replace it. I found a link on youtube that may help you to locate and replace the filters: http://www.youtube.com/watch?v=wGsuVK8KTT0
Apr 04, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
BB1100BdD stops after a few minutes operation. After an hr or so will run again for a few minutes
The motor is overheating and control features cause it to shut off to prevent burning it out. First check the bag. If it is full, remove and replace with a new one. A full bag can cause the motor to work harder, and thereby overheat. Next check the filters. A dusty filter will keep air from cooling the motor and again cause overheating. The HEPA filter needs to be checked also. Most filters can be dusted off. Some can be washed, air-dried, and replaced.Others will need to be removed and replaced. Your owner's manual should tell you how to clean filters. I hope this helps. If it solves your problem, please let Fixya know and post a rating for my solution.
Nov 19, 2010 | Oreck BB1100DB / BB1100DC Housekeeper...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Black & decker parquet 1800w hepa h13 need
I'm not sure what bag your referring to. The only bag for this is the carrying bag. So I have to assume you mean one of the filters.
There are three filters for this vacuum.
  • Primary Filter.
  • Exhaust Filter.
  • Secondary Filter Element.
I have included a link to a site that carries the replacement parts and a diagram of the vacuum.
Hope this helps.
On another note If it doesn't help I really don't feel to bad because I'm in Detroit Michigan. And I'd rather have a dozen useless vacuums hanging out in New Zealand any day. :)
Find me a job there and I'll buy you a new vacuum. :)
http://www.ereplacementparts.com/black-and-decker-hv6000-type-opp-corded-hand-vacuum-parts-c-4167_8887_10329.html
Oct 17, 2009 | Black & Decker HV6000 Bagged Handheld...
I need to clean the main filter
Be sure you wash the filter that is above the canister compartment. It has an orange lever to release it. I over looked this the first year I had the vaccume, dust was really caked in there. I also just wash out the inside of the canister with water once in awhile.
Mar 18, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuums Logo
364 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
