Not enough agitator action.
Whirlpool 5132E. I've had a guy come and fix it twice in the last year, it takes him about 5 mins and costs $160. I'm sure I could do it myself, on the invoice (I can't read his writing) to find out what part I need to buy. So if you have any ideas about what the part might be and repair instructions, I would greatly appreciate it.
  • Tunn Mar 14, 2008
    Thanks so much! It took about ten minutes to fix and I just saved $120-- money better spent on a new dress.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds like you need a set od AGITATOR DAWGS. part number 80040. located with iin the agitator it self. with the heel of your hand hit the fabric softener sectio off agitator. reach down inside agitator and remove the opaque seal. under there is a 7/16 bolt. this will release the agitator all together, tip it over and hte inner workigs should fall out. the dawgs are small plastic "gears". should be self explanitory at this point . reassemble, and you just saved about $150
Posted on Mar 13, 2008
F1 error code
Revolt! If you own a Kenmore Oasis (built by Whirlpool) or Whirlpool Cabrio washer, and you are getting the "F1" error code...or similar codes, and nothing you do fixes the problem...REVOLT!
Three options: Join the class action lawsuit, sign the petition, or be a just another chump consumer. All info is below. I for one, have HAD IT with a 1000.00 washer that breaks after one year.
Here is the class action law suit info. I got
this email a couple of days ago. Remember, these Kenmore Washers (built by Whirlpool) are basically the same machine as the Whirlpool Cabrio:
"Thank you for your interest in pursuing a lawsuit against Sears relating to the Kenmore HE4t and HE3t Washing Machines. This lawsuit is currently being handled by the law firm of Seeger Weiss, LLP. Sheller, P.C. is co-counsel on the case. Your inquiry submission will be forwarded to Seeger Weiss, and you will be contacted by a Seeger Weiss representative shortly."
Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz1qRPaiZXt
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
WHat is the capacity of the Whirlpool LLR9245BQ1 top load washer?
Hello there
  • Washer Type: Washer
  • Load Type: Top Load
  • Volume Capacity: 3.2 cu/ ft
is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
Jan 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
5 year old Whirlpool Gold washing machine wont spin or drain. I hear the motor hum, but wont engage. Number is GST9630PW1
Easy solution: NEVER BUY A WHIRLPOOL PRODUCT. It's only 5 years old. You spent good money. In reality, this machine is doing exactly what WHIRLPOOL Corp. programmed it to do: FAIL.
NOW, you call the service guy. They tell you it will cost about $500 to $600...which is really not a good solution. Because in 5 years, this stuff happens. The best solution is to BUY A NEW WASHER. Mission accomplished! Sell product. FIX -ha! That's how things were when our grandparents purchased appliances. Parts could be replaced. That's no longer the deal.
Dec 09, 2010 | Whirlpool Washing Machines
Machine dot draining, not completing cycle.
check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
Feb 11, 2010 | Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Dec 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
