Question about Panasonic NN-T993SF Microwave Oven
Door shut off malfunction
Panasonic NN-T993SF 1350 WattsThe turntable and fan (NOT the magnetron) run when I open the door. I think the door interlock is sticking, if I probe the lower interlock I can get it to stop, but the next time I close and open the door the turntable and fan start up again. Otherwise, it works as normal when the door is closed.
  • 1 more comment
  • Anonymous Sep 21, 2008
    Same Problem, Does anybody have an idea on how to solve?
  • swaite Sep 27, 2008
    THe same problem with my T993 just started 2 days ago.
  • Anonymous Mar 27, 2014
    When closing the door it does not click shut tightly to start the microwave.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a similar problem. The only answer I got said I might have a falty switch, to witch I replied the the problem was logic and not necessarely mechanic. If you get deeper insight let me know please!
Posted on Nov 18, 2015
I have the same problem starting yesterday April 19. Have you gotten any answers.
Posted on Apr 20, 2008
SOURCE:
Panasonic Invertr NN-S963, no heat and shuts off approx 7 sec. before end time. Fan works. Is it magnetron? If so, approx. how much to fix?
Magnatron failure is rare. I suggest you check your door interlock safety switch. Do you regularly open the door while the machine is running? I did and I found out that the micro switches (door safety swwitch) are just not up to that kind of abuse. Your maching thinks the door is open because the contacts are burned to the point they do not close.
Unplug the machine, DO NOT TOUCH THE SILVER CAN! You will find the switches opposite the hinge. Check them with a volt ohm meter on contunity setting.
You cam probably get replacement switches at a electronics parts place.
There are other things that can be wrong but you should check these switches first. Cost should be less than $10.00 if you do it.
Let me know if this works for you.
a
Sep 21, 2009 | Panasonic NN-S963BF Microwave Oven
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Panasonic - NN-T993SF 1350 watts microwave
Sorry this is something you wont fix at home I couldent even do this one.This is a nice unit depending on the cost this one I think is worth the repair bill , Good luck DFD please rate me TK U
Apr 12, 2009 | Panasonic NN-T993SF Microwave Oven
T993 - Positive Lock Switch ?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Nov 03, 2007 | Samsung SMH7159 Microwave Oven
Panasonic NN-T993SF Microwave Oven Logo
577 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
