Question about Kidde Nighthawk Combo Gas/co Detector
Gas code 210
What does this code mean?
  • 667 Answers
Does the co alarm sound and display show 210? This means you have 210ppm co. This is not good. Are both the gas and co alarms goig off? Try resetting but if it's working properly you've got a pronlem. Check this link for further info: http://www.kiddeus.com/utcfs/ws-384/Assets/900-0113.pdf
Posted on Mar 12, 2008
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
What does code u1411 mean for 300c
http://repairpal.com/dtc-code-u1411-210
posted for a jeep, same thing as your chrysler.
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Sep 01, 2014 | Cars & Trucks
2003 chevy trailblazer code p0420
Is your engine temperature at 210 degrees? Need a scan tool for this, the guage isn't reliable. If not, cheapest thing to do 1st would be change your thermostat if it's not at 210. If that doesn't work, have your catylitic converter back pressure tested. You could try some Cat Clean added to your gas too as cats are expensive.
Feb 28, 2014 | 2004 Chevrolet TrailBlazer
Error codes P0128 & P0442
Well code 128 is for the engine running too cool. Which is usually a thermostat problem. But it could be the coolant temp sensor.
You may have a different sensor for the gauge and for the computer.
Code 442 is for a small leak detected in the EVAP system. It can be a faulty gas cap, but since you have replace the cap, its probably a hose or gasket. The computer vents the gas tank to the vapor canister when the engine is running. It checks gas tank pressure to make sure all valves are closed when you turn the truck off.
Apr 11, 2013 | 2005 Buick Rainier
2003 GMC Envoy Service Engine light on. OBD2 Code is P0128
Ah the famous P0128.....It's 1 of 2 things. If your fan is not engaged constantly (would sound like an airplane or big rig everytime you step on the gas) and is working properly, that rules out the fan clutch. The other common problem is the thermostat. Replace the thermostat and the code will go away. Engine temperature needs to be at 210 degrees on these engines. If the fan clutch is constantly engaged, it's cooling the engine off constantly and won't get up to 210 fast enough. If it's the thermostat, it's stuck open and isn't allowing the coolant to properly heat up in time.
Feb 08, 2011 | 2003 GMC Envoy
Error code c0000 in bizhub 210
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
Jul 07, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica minalota 210 error code detials can everyone can give me the error code
If you are asking about a C0 210 code on a Minolta Di183 then this code means there has been a abnormal image transfer voltage error. The service manual says "the image transfer voltage remains more than 100V for a continuous given period of time while the PC drum remains stationary".
Have you opened/closed the front door or turned the machine off then back on to reset the code and see if it returns?
27 years working on Minolta copiers and I have never seen this code on this model of machine before so hopefully it will reset. If not you will need to call for service on the machine.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Konica Minolta DiALTA Di183F Copier
Gas alarm keeps going off. No smell of natural gas in the house. It has happened 3 times before in the last month. It then shows number 210. What does this mean?
Depending where it was installed your sensor in the unit may be dirty. Try to vacume or blow air into the sensor this may help. If it dosen't toss it and buy a new one. please check your instructions carefully as to where it should be installed.
Apr 22, 2009 | Kidde Nighthawk Combo Gas/co Detector
Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Kidde Nighthawk Combo Gas/co Detector Logo
363 people viewed this question
Top Kidde Home Security Experts
Marvin
Marvin
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
