Question about Whirlpool ET8RHMXKQ Top Freezer Refrigerator
WATER pooling in bottom of fridge
Hello, I have the whirlpool ET8RHMXKQ. Water has been dripping down from the freezer into the fridge, and pooling in the bottom, but also wetting everything in the back of the fridge on its way down. We have cleaned it, checked the freezer for build up and not found anything. This model came w/an ice maker which we had disconnected and removed about 3 years ago as it is not hooked up. The fridge and freezer are still cooling well. Any ideas?
  • karenmck Mar 17, 2008
    Thanks, we'll give it a shot.  Appreciate your help!
  • Anonymous Mar 23, 2014
    Sandstrom fridge freezer
    President:
  • Whirlpool Master
  • 2,651 Answers
Did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 13, 2008
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
The freezer (top) works fine but water leaking in the fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 31, 2010 | Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Refrigerators
Whirlpool Fridge has water leakage
have you been filling it up with more food than usual? how are you storing the food? if its touching the back of the fridge then this causes the water to drip down the back and accumulate at the bottom. I had the same problem (different fridge), I'd open the fridge and there;d be a pool of water at the bottom, sometimes it even started leaking out onto the floor.
so... i just made sure when i put food in that it wasn't all pushed to the back and that none of it was touching the back of the fridge - no more water at the bottom!
give it a try , hope this helps.
Jul 31, 2008 | Whirlpool Refrigerators
Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Feb 23, 2008 | Refrigerators
Whirlpool ET8RHMXKQ Top Freezer Refrigerator Logo
365 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
