Question about Refrigerators
Maytag fridge w/bottom freezer
Suddenly the freezer is no longer frost free. It's not that old.
What can I try before calling in the repairman.
It's an Amana with the freezer on the bottom
  • dfisher Mar 13, 2008
    I'll check that out..if I can find the defrost thermostat..I'll keep you posted.
    And..thanks
  • korrie12 May 30, 2008
    I am having the same issue. So any advice would be great before I just throw it out.
    Model: Amana
    Problem Solver:
Since no one is answering I do have some knowledge, check the defrost thermostat, which puts the unit in defrost mode to melt small frost build-ups, also check seal on your door to make sure you are not getting warm air leaking into freezer, good luck
Posted on Mar 13, 2008
SOURCE:
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Fridge not defrosting right water in bottom of freezer then turns to ice.
It sounds like the unit is defrosting, but the drain for the water from the melted ice is plugged. Check that before calling a repairman.
Sep 28, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
LG GC299BA Fridge working but noisy, freezer broken.
It sound rather like one I used to have (but worse) which was never 100% satisfactory. When it eventually failed we called in a repair man who said it had been faulty since it left the factory.
I advise you to scrap it and but a new one. If you have any similar problems with new equipment, go back to the supplier within the warranty (if you have an extended warranty, then call them out now!).
Jan 23, 2010 | LG Refrigerators
Freezer not freezing
When was the last time you cleaned the condenser coils? They are either on the bottom of the unit (underneath) behind the grill, or on the back of the refrigerator. Use a refrigerator cleaning brush' (available at most home centers) to do the cleaning, or call an appliance service technician to accomplish this. After that, it could also be the compressor, or the condenser fan (bottom mounted coils), or a 'freon' leak. Call a repairman then!!
Dec 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
AN OLD GE FROST FREE BOTTOM FREEZER REFIRGERATOR. LIGHT IS ON BUT DOES NOT KEEP ANYTHING COLD. THIS IS AN OLD AVOCATO COLOR REFRIGERATOR WITH A BOTTOM FREEZER. I AM FAIR WHEN IT COMES TO REPAIRING THINGS....
Wow avocado green! Didn't know bottom freezer models were made that long ago. Make sure all fans and compressor is running. If all that is running and still not cooling, time to get new Fridge.
Sep 27, 2017 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
MFD2560HES Service Manual
defrost is your problem (heater, terminator, or defrost control)
Nov 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
