Mitubishi VS5062 Any Ideas where I can find a replacement pip board or the PIP modification to eliminate the board?
  • K9lz Mar 13, 2008
    Hi Slinteriors,
    The fix gave me the pix back. Now I have retrace lines, flutters, sprites and other fiddley widgets on the screen. Is there an easy fix for that? If not what do you recommend in 60" LCD screen TV's. (No Plasma tnx I don't really like the pix on them.)
    Tnx again,
    Lou
  • 8,617 Answers
You can bypass the PIP module using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video.Just solder a length of insulated wire on the capacitor leads so they wont short out crossing over each other. just plug the lead wires directly into the main boards connector where you removed the PIP board.
Posted on Mar 12, 2008
  • Sonny Berry
    Sonny Berry Mar 13, 2008
    I have also tried this fix on some mitsubishi models when the standard Bypass didnt work. You can try this to see if it works.
    The solution is to put the - side of a 4.7uf cap to pin 5 and put the + side to a 2.7k resistor, the other end of this resistor goes to pin 11. Then take a 4.7k resistor, attach one end to pin 11 and the other end to ground at pin 4 . This drops the 2vPP to 1VPP. I do this with the VP connector off the PIP board and use the connector only. For the chroma I use a 1uf cap from pins 7 to 9 with the - at pin 7. The only LCD I could even begin to recomend would be any of the Sony models In my opinion nothing else comes close for picture and sound quality.
  • Sonny Berry
    I wanted to mention that I have a source for obselete mitsubishi circuit boards if you would like me to try and locate one for you. Let me know and I will see what I can come up with. Just post the numbers off your PIP module.
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
Mitsubishi CS-35301 has a rolling screen. Need to access service menu.
you need replace capacitors in vert.output circ. Not a service menu.
Jan 28, 2010 | Televison & Video
Where is the pip board located on a Mitsubishi vs-50605?? need to know so i can replace caps please!
what is the problem with your set? I can only find a small stand up board on the signal pcboard that has anything to do with pip. I can't find anything on the mitsubishi web site that says anything about changing any caps on a pip board.
Aug 18, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi TV hand me down
the problem you have is the video goes thru the pip board first and the pip board has a problem this is a known problem. the pip board has some capacitors that leak on the board. the model you mention is CS-27MX1 not XM1 but anyway the back casing was made for several sets of that size. so the pip is the problem and the bulletin is as follows;
1. NO MAIN VIDEO,THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB.THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PT#181P504090. 2. NO MAIN OR PIP VIDEO, CHECK CHECK C7014, 47 UFD 35V ON THE PIP PCB. PART # 181P502060 3. CHECK FOR 7.2V DC ON THE BASE OF Q7003,IF LOW OR MISSING.CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PT#103P401050 you can by pass this by removing the pip board and jumping the VP connector pins 7 to 9 and 5 to 11
Mar 07, 2008 | Televison & Video
CS-27403
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Jan 27, 2008 | Mitsubishi VS-45605 50" Rear Projection...
My tv
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Dec 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Apr 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Intermittent vertical jitter.
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
Nov 08, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi cs-26ex1
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Oct 17, 2006 | Mitsubishi CS-27209 27" TV
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
