Question about Hawking HWREG1 Repeater
HawkingExtention the ip address will not atomatically assign and when i assign it manually from the cmd system it still does not seem to be right
    Genius:
  • 3,587 Answers
What's the problem when assigning it manually?
Posted on Mar 15, 2008
Need to know wat ip number is and port is
IP stands for Internet protocol.
It's represented by numerical code, which is assigned to each device like computer, printer, phone.
IP's are two types. There are Internal IP, External IP
Internal IP means that your system ip address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system ip address
External IP address means that your network IP address. If you want to know your Network IP address then visit IP-Details.com here it display IP address, ISP,location, Longitude, latitude and so on.
To find your port number follow these commands:
Go to start--->cmd---->type netstat -a
Feb 02, 2014 | Televison & Video
Tip
Windows XP: How to release and renew IP addresses
IP addresses can either be assigned manually or automatically. When they are assigned automatically, a DHCP (Dynamic Host Configuration Protocol) server hands them out and determines which computer or other device gets which address. This process usually flows smoothly, but there are times when you may need to release or renew an IP address even when using DHCP.
There are several ways to release and renew IP addresses in Windows XP. Each procedure is described below.
From the system notification tray:
1. Right click on the network connection icon in the system notification tray.
2. Select Repair. Windows will automatically release the current IP address, reset the network connection, and request an IP address from the DHCP server. (The new IP address that gets assigned may be a different one from before, or it may be the same one.)
From the Start menu:
1. Click the Start button.
2. Right click on My Network Places.
3. Select Properties.
4. Right click on the network connection that is currently in use.
5. Select Repair. (If you choose a network connection that is not in use, Repair will be grayed out.)
For either of the above methods, you can release and renew your IP address manually by clicking Disable instead of Repair, and then right-clicking and choosing Enable.
From the command prompt:
2. Click Run.
3. Type "cmd" and press [Enter].
4. At the command line, type "ipconfig /release" and press [Enter].
5. Type "ipconfig /renew" and press [Enter].
6. Type "exit" and press [Enter].
on Feb 02, 2011 | Microsoft Windows XP Home Edition
My V3-772G-9643 laptop can only establish "limited" internet access with my wireless network. Other devices are able to connect to the internet without a problem. I have attempted to diagnose the...
suspect you have a router that assigns ip address ?
or does the wi fi access point assign ip addresses ?
This is known in techo speak as a DHCP server that manages the setting up of the ip addresses automatically.
in simple terms you go into the ip address settings of the mystery operating system which from your laptops model number should be windows 8 64 bit version.
this you tube video explains how to go into the ip addresses
https://www.youtube.com/watch?v=iF6V0orA0Cg
if the ip address is set up manually
go to a computer that does work and get the ip address , sub net mask and default gateway ip address and set up on your laptop that has ip not working an ip address that is not used by the other computers it cannot clash with another computer.
https://www.youtube.com/watch?v=P4T9hgDVhG4
to get into cmd in windows 8 go to desktop not start screen !
then right click windows icon bottom left corner. then select command prompt
then set up manually as shown in
Jun 02, 2017 | Computers & Internet
How to assign IP address through command prompt. Kindly share the screen shot as well ?
STEPS TO ASSIGN STATIC IP ON ANY INTERFACE THROUGH COMMAND PROMPTExample IP's ,Subnet, gateway
1. Click on start
2. Click on Run and type cmd. Press OK.
Now the command prompt will be opened.
3. Type the command
netsh interface ip set address name="Local Area Connection" static 192.168.1.5 255.255.255.0 192.168.1.1
Where Local Area Connection is the interface name.
The static IP address we assigned to the interface is 192.168.1.5.
The subnet mask is 255.255.255.0
The default gateway address is 192.168.1.1
Feb 09, 2011 | Microsoft Windows Server Standard 2003 for...
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
No ip address
Network Card's driver is not installed. Check and install drivers from Device Manager Window.
IP Address can be assigned automatically(through APIPA/DHCP) or Manually.
Automatic:
There is no DHCP server, it takes the Automatic Private IP address(APIPA) or else get it from DHCP server by using "ipconfig" command
Steps: Start>accessories>command prompt>ipconfig /renew
Manually:
Right click on My Network Places> Properties>Right click on Local Area connection>Properties>General Tab>select Internet Protocol(TCP/IP)> Properties>General> select "Use the following IP address> assign IP, Subnet Mask, Gateway and DNS> Press OK Tab.
Dec 10, 2009 | Dell Dimension 3000 PC Desktop
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
No ip address on computer
IP addresses are generally assigned when you connect to another networking device such as a router, switch, or modem. You should first go to your Network Connections and right click on your networking device and click on properties. Click on Internet Protocol (TCP/IP) and hit properties. Then click on the box that says Obtain IP address automatically and Obtain DNS server address automatically. Now when you make connection with the router, switch or modem it should assign you an IP address. If this doesn't happen then you need to check your network cable, or wireless log in proceedure to find out why you're not connecting. These rules aren't for all systems. Some ISPs may require you to put in DNS servers and IP addresses. If the above doesn't help then contact your ISP to find out if there are specific settings. You can also view your Network Configuration settings by going to "Start" > "Run" cmd then in the window type /ipconfig /all. If you're connected properly you should have IP address, default gateway, DNS server and DHCP servers.
Oct 04, 2009 | Dell Inspiron 2200 Notebook
Assign address manually
hmmm....so, how is the IP address NOT working for you? Can't see it from your computer? A bit more detail please..
Mar 15, 2008 | Hawking HWREG1 Repeater
I cant log into my router even though I am using the 192.168.1.1 subnet mask
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
Jan 13, 2008 | NetGear WGR614 Wireless Router
Hawking HWREG1 Repeater Logo
277 people viewed this question
Top Hawking Computers & Internet Experts
Marvin
Marvin
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
