Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
I'm dissconnected from site
I don't know how to get connected again with you
What do I do now?
Posted on Mar 12, 2008
SOURCE:
Horizontal line on my notebook monitor
Your monitor may have a bad screen or wiring to it. If you know how to dissasemble it, then first check the ribbon cable connecting the screen to the main pc board. If you dissconnect it and reconnect it and it doesn't go away, then your screen may have the problem. This will have to be replaced. If you don't feel comfortable to replace it, I'd recommend finding a local repair center near by. It's usually around 150.00 +/- . good luck. chris
Feb 28, 2012 | Computers & Internet
How do I remove an aftermarket Engine Immobiliser that looks like a stereo plug that i've almost lost twice and my brother thinks it's hooked up to the fuel system I don't want the stress of almost lo
Most immobilisers on the year car 1993 and some newwer one are connected to starter wiring under the dash, and what it does is it cuts the power wire from the ignition switch in half and sends it through the module and to relay, you will need to follow the wires and you will see the wires coming down from the ignition switch, one will be cut in two and go into immobil wiring you will dissconnect them and reconnect them back together, the wire is color coded so theres no mixing wires and then the rest of the wiring will be to power and ground and so on, all these other wires can be removed or left there. once you connect the main stating wire thats the main wire, a quick thing to see if this is the way it works is to try and start the car without the chip and see if when you turn the key the engine should not try to start, it should do nothing just dash lights light up but no engine spin, if this is what happens then this is the way to dissable it. good day.
Dec 06, 2011 | 1993 Toyota Corolla
Heater has quit working, how do i know if it is switch or fan or something else
IS THIS YOU AC FAN OR IS IT A DIFFERENT FAN. If it is the ac its not the motor mine turned out to be an earth problem for the fan when i connected it to another eath in the car fan started working again but remeber to dissconnect the new earth to see if fan still works off controller worked for me
Jan 26, 2011 | 2001 Volkswagen Passat
My air conditioner just quit working. how do i run my own diagnostic or just get it running again. i switched the breaker on and off to try and reset it but it didn't work this time.
first does the furnance blower work ? go outside to condensor unit .their will be a dissconnect box connected to the unit. open door to dissconnect pull out connector or fuse holder to see fuses check with ohm meter replace the bad one time delay fuse s only p/s turn the breaker off before pulling dissconnect out please be safe good luck
Aug 23, 2010 | Amana Heating & Cooling
Laptop dissconnects offten and takes a while to connect
Great job. Now what you need to do is make sure you are running the latest firmware version.
Try upgrading it by downloading the latest from Belkin's support site for your model.
Nov 18, 2009 | Belkin F5D7230-4 Wireless Router
Compaq presario r3ooo screen fades to black, then intermittently picture returns then fades away again.
check the connection to the motherboard it may be lose dissconnect it and reconnect it or you lcd converter may be going but try the conntection
Nov 02, 2009 | Compaq Presario R3000 Notebook
Car was disabled under the hood, how do I fix that?
The battery is most likely dissconnected. Locate the battery and make sure the + and the - are propperly connected.
May 20, 2009 | 1980 Cadillac Eldorado
When i try to setup the security on my wireless router it dissconnects and will not let me connect again untill i disable the security settings
that is correct. When setting up wireless security in the router, do a wired or direct connection to the router first.
Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sansa clip 1g frozen wont reset do i need update, thats what caused this mess
did you try pushing the power button up and holding it there for about 10 seconds?
Oct 25, 2008 | SanDisk Sansa Clip MP3 Player
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
