Question about Sony KP-61HS10 61" Rear Projection Television
Kp-61HS10 tv turns on and off nonstop. sometimes you can hear the sound but no picture and it wont stay on at all. just keeps turning on and off.
  • 1 more comment
  • tv breaker Mar 13, 2008
    No the LED does not come on or blink. If the Audio comes on it will blink as it turns on and off. Either way it still just turns on and off.
    No I tried to locate one today, but was unable to find what I was looking for
  • mbg1958 Aug 02, 2008
    This happened to me and it was one of the front panel buttons being stuck under the frame. Turned out to be simple
  • Sony Master
  • 8,617 Answers
Protective shutdown, being as sometimes you have audio leads me to believe its vertical deflection. Does the Led flash when it shuts down?
Posted on Mar 12, 2008
  • Sonny Berry
    Sonny Berry Mar 13, 2008
    No blinks means its not going into protective shutdown so you will need to trouble shoot the deflection circuits something is stopping the oscilation. Do you have the service manual for your set? You will need that for sure to even begin to troubleshoot the deflection circuits.
  • Sonny Berry
    I am posting a link where you can get your service manual emailed to you almost instantly. It cost 10.99 and they offer free support to help diagnose your problem. Your model is located on page 2 of their Sony section.
    http://servicemanuals.vstore.ca/
SOURCE:
Sony KP-61HS10
Five blinks is a video abnormality detection and I am all too familiar with this repair... One or more of the crt's in this unit has a bad set or failing guns in it... You can have a local tech bring out a crt tester and rejuvenate the tube for a temporary stay but it will eventually fail for good and in a short period of time it will be one or the other - - VERY expensive to repair or off to the dump...
Please don't kill the messenger!
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
