Question about Motorola Mobility RAZR V3
Bluetooth problem My razr will pair with my Plantronics 330 headset,phone rings in headset, but no sound when trying to talk. I tried headset with another phone,works fine.Is there a setting on my phone I need to change(it worked fine for a couple of days, then stopped).
    Brigadier General:
  • 7,752 Answers
Try resetting the phone and pairing the device again and see if that helps.
Posted on Mar 21, 2008
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Plantronics Explorer 330 User's Guide
Good luck from Headsets Direct!
Jan 05, 2011 | Plantronics Explorer 330 Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 20, 2010 | Plantronics Explorer 330 Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
Dec 21, 2009 | Plantronics Explorer 330 Headset
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice...
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Jul 12, 2009 | Plantronics Explorer 330 Headset
Bluetooth code Plantronics 330 to LG AX300
try these codes
1234
4321
9876
6789
9999
0000
one of them will work
best of luck
please remember to rate me.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Plantronics Explorer 330 Headset
Pairing plantronics bluetooth 330
The code is four zero's (0000).
Mar 01, 2009 | Plantronics Explorer 330 Headset
I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320
Jan 10, 2009 | Plantronics Explorer 330 Headset
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
indicator light flashes blue and
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
to search for Bluetooth devices
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
PASS CODE
thanks sooo much this worked wonders!
Nov 01, 2007 | Plantronics Explorer 330 Headset
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
