Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Power surge problem with panasonic plasma
Hi
did you solve your problem from the power surge anf the flashing lcd? I'd appreciate any help Thanks
  • 61 Answers
SOURCE: 42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Posted on Oct 09, 2008
  • 53 Answers
SOURCE: (panasonic TH-42PZ77U plasma) the tv will power on
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
hope this helps!
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: power light flashes green
Ok, if the set was not protected by a formidably surge protector, it has most likely received a direct hit. this has completely rendered the power board useless at this point. it is unable to distribute the proper current throughout this unit. The replacement of the damaged power board is needed in order to restore this unit.
Posted on Jul 09, 2009
dsacco86
  • 1077 Answers
SOURCE: Panasonic plasma hdtv will not power on
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Posted on Sep 12, 2009
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
Hello, lighting hit and my plasma Panasonic tc-42px24 will not turn on. completly dead. was told it maight be supply board??? thanks
Power surges wreck havoc with power supplies since they are first in line and bear the brunt of the rushing power. Try replacing the power supply board on the cheap by getting a used one on ebay to minimize the expenditure in case that is not it. Always a possibility,
Sep 09, 2015 | Panasonic Tc-42px24 42 in. Plasma TV
Panasonic Viera TC-P50U2: No Pic., Red Light flashes 6 Times, I think I need a YSUS card, for S C energy recovery. Can anyone confirm this and , tell me where to get the card Also instructions on...
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 28, 2013 | Panasonic Tc-p50u2 50-inch 1080p Plasma...
I have a Panasonic Viera TC-P50U2 Plasma HDTV. Problem: No Picture. Red light flashes 6 times . I believe it needs anew YSUS board, SC energy recovery ckt. Can anyone confirm this and tell me where to...
Sep 27, 2013 | Panasonic VIERA Televison & Video
Panasonic plasma flashing red light
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
TC-P50S1 will not power on after power surge
try unplugging from power for at least 30 seconds. if that doesn't work, it may be a fuse. see the picture for the fuse location.2_25_2013_1_41_21_am.jpg
Feb 24, 2013 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Plasma panasonic headache
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
231 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
