Question about Nakamichi SoundSpace 5 Shelf System
Need new speaker connections
I have to replace the speakers or just the cables and the connectors to the speakers. Any body know where I can find parts or where I can just buy the speakers?
  • 24 Answers
Yes try Bogue Engineering Group at www.BogueEngineering.com they have a full ine of speaker connectors and many different options including 18, 16 and 14 gauge cables.
Hope that helps, Gary
Posted on Jul 23, 2009
6ya staff
SOURCE:
How do I repair
I guess you have tried switching the speaks left to right to check its the speaker rather than the output to the speaker?
If you have it might be worth (If you are able to) opening up the speaker unit to check the wires are still attached and solid, maybe need a little re-solder is needed as the wires are usually very thin.
Sep 19, 2014 | Altec Lansing VS2121 Computer Speakers
Replace 2002 Range Rover Speakers with after market speakers
Yep thats ur best bet find what one is pos and neg and just wire in new connectors. Be sure u replace with same size speaker. Ie 6x9 4x8 etc. That way no holes need to be drilled other then the ones u might have to mount the specker. As well take a note of how good the wire is running through the door to the main body if u do all this work amd pull on the wires they may have already been broken innside where the door bend is if this is ur case u will habe to re run new wires from the speaker all the way through the door. The jam. And into the side kicker panel this way u know for sure ur wires are solid. Good luck.
Feb 21, 2018 | 2002 Land Rover Range Rover
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
My Boston Acoustics BA735 speakers does not fit to my new Dell VISTA PC
I wish these suggested responses were a fix for my need of the control pod that connects to the main base unit on BA MM226 model. the only one I would consider is the repairman in Beaumont... b7e3fdeb-da2e-497e-b5a9-c73017f7f98a.jpg
Sep 07, 2008 | Boston Acoustics BA735 Computer Speakers
Speaker problems
Hello there
Happy Holidays!
well, I suggest 2 things here, you can replace the speakers for a new pair, or see if connector or inside of the failing speakers, to see if the positive cable is connected, or the negative, from that you also check the wire connector end, if is in good condition too.
Dec 23, 2007 | Packard Bell Speaker Computer Speakers
I don't know how to properly hook up to an HP m9060n computer.
you must connect the cables, and configure the pc yo work with it.
you must configure pc according with the cables/setup you connect.
Nov 27, 2007 | Altec Lansing ADA 885 Computer Speakers
Nakamichi SoundSpace 5 Shelf System Logo
189 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
