Question about Maytag M7DH45B2A Dehumidifier
UNIT WILL NOT TURN ON
When I hit the power button, nothing happens. I cannot find my manual, or one on-line. Is there an internal fuse I could check? Thanx
  • moongrove Apr 07, 2008
    my dehumidifer will not turn on. no power, nothing. what do I do? I unpluged from wall and left unplugged for 10 min. still no power when re plugged into wall socket. Unit only 3 yrs old.
  • 25 Answers
Cause:
Assuming the fuse is good. I believe the cause of this problem is corrosion on the heating element clip leading to the heating element hanging free away from the air-exit radiator. This may lead to water accumulation in places that are undesirable such as under the power board.
Solution:
1. Replace or repair the power board (COR268BV1.0 or COR217BV1.4). See http://www.appliancefactoryparts.com/images/products/2/291480-3.jpg for reference on the COR268BV1.0 traces. I do not know if they are interchangable.
2. Replace the clip. Maybe you can use steel pipe clips from your local hardware store to make one, if you cannot find one online.
Posted on Jul 07, 2010
Same here. No power. Took it apart and everything looks good. No loose wires or anything unusual.
Posted on Jun 28, 2008
  • marine2000 Jun 28, 2008
    Update, I took off the circuit board where the main power comes in. There was some corrosion under the board. Must have gotten water on it somehow?
    Anyway, the PN is COR268BV1.0. It is still under warrenty, so I'll have to see what can be done. One thing is that it does look like a bad design. The soder under the board was very close to its neghbor. Looks like it would be very easy to get a short circuit.
I am having the same problem with mine. It's plugged in and everything looks as it should inside, but i can't get the thing to turn on.
Posted on Jun 22, 2008
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Jun 02, 2014 | LG Dehumidifiers
We have a model AD-40A dehumidifer that I believe is approx 3 years old. When the unit is plugged in, nothing happens. Although it appears to be getting power (when you pull out the water tank, the...
You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
Aug 17, 2011 | NewAir AD-40A Dehumidifier
Plug the unit in, hit the power switch nothing not even the lights for the buttons.
Check the outlet that the unit is plugged into, to make sure that it has power. The circuit breaker for that outlet may have been tripped. Also make sure that the outlet is not damaged inside or there could be a loose wire connection or a frayed wire to the outlet.
Hope this helped you to start troubleshooting and solving the problem.
May 18, 2011 | Kenmore 54501 Dehumidifier
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Unit does not turn on when the on-off button is pressed. No indicator lights come on. The line cord is good - I have 118 volts across the black and white wires inside the cabinet.
This unit has a 12 amp 125v glass tube fuse on the control board. Chances are you blew this fuse. This can happen if the unit is starved for air and ices up. you must take the front of this unit off to access the fuse of this control board.
Apr 08, 2010 | Haier HDN655E Dehumidifier
My DH504ELY7 unit quit working.
look for A fuse probably gonna be internal or a lil breaker or a reset button
Feb 22, 2010 | Goldstar DH504EL Dehumidifier
Control panel lights up-nothing else happens
first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Dec 16, 2007 | Kenmore 5365 Dehumidifier
Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Aug 10, 2007 | Haier HDN655E Dehumidifier
Damby ddr451
Check your tank. Remove it and look to be sure that there isn't any shipping foam or foreign objects in the area which may be keeping the safety switch open. If the area is clear check the switch to make sure that it is not stuck and it moves freely. If that is OK replace the tank and make sure that it is installed completely and correctly. Try it again. If it still does not work I would take it back to the store and have them check it out under the warranty. Good luck.
Jun 29, 2006 | Danby DDR451 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
247 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
