Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick is going crazy wont turn on anymore
Ok so heres problem yesterday i was talking on my sidekick everything was fine then the person on the phone hanged up on me and i went to look at my phone and it locked up. so i turned it off and turned it back on then it worked for a few mins then locked again. so i took out my battery and tryed it again and it wouldnt even go past the first screen it shows when it powers up the first box is all i saw. so then i pluged it into a charger and it turned on and worked fine so i let it charge to 100 percent it was at 70. i unplugged it used it for about 3 hours then it locked up again during a phone conversation(texting had been working the whole time to by the way). so now it wont stay on at all and the min i take it off the charger it locks up iam not sure what to do the battery may be the problem but if it was wouldnt it make the screen blank not lock up all the sudden. Also when it sits there with the one box some times the trackball will flicker green and there will be a line across the screen. and the box will go dim and then dark again.
and i do not have warranty on this phone any longer so iam screwed if my phone is messed up. so please help me guys
Ohh all you gotta do is get a good looking ***** and put it in her ***** then lick the **** it should work
Posted on Oct 06, 2008
    President:
  • 625 Answers
This problem was said a lot by some users when the first batch of sidekick 3's were released last year. What you do is do a soft reset @ + 1 + 0 and then when it shuts down quickly hold down the W and when you see it restart you should see the sidekick 3 picture with a face on it and stars above its head, and from there you select English and you follow what the screen says to help you get past the bootup screen.
if you continue to have a problem, try removing your memory card and see how the phone works for a while.
Posted on Mar 13, 2008
2 Suggested Answers
SOURCE: sidekick 3 trackball problem
blow into the trackball area really hard..should dislodge some particles on the sensors.
Posted on May 07, 2008
92 Suzuki Sidekick stuck in park-where do i find the magical switch or pin that will let me shift out of park that everyone is talking about?
why do other say to replace the most hard and expensive part first.
wow, what bad advice, !!!
yes, the shifter has the bypass, lever. see link. below and photo.
now the facts: (from easy and cheap to harder)
1: brake lamps dead, (both)
2: brake lamp switch dead.
3: wiper fuse blown causing park lock relay to be dead.
4: park lockout relay , bad.
5: PRNDL switch bad, in park. or cable snapped .
if bypass works, then the cable is not snapped, trans works,. see?
6: last the solenoid can be bad. (only if 12vdc makes it here)
(notice no lies or guessing)
randy, we had 3 of these cars , you zero.
http://www.fixkick.com/tranny/shiftlock/ParkLock_fails.html
here it is , that which randy never saw or read in the oper. manual
need one? have it , can send. page 25 in mine.
remove cover A slide the lever, and shift to drive. or rev.
magic and this photo is in your operators guide, in all sidekicks up to 1998 at least.
no bs , the real deal, on Trackers ,sidekicks and vitara's
89-98. with A/t
25996191-fuelrpya0ajd2uthzrr5rxwa-2-0.jpg the super magic, super secret , park lock bypass, for real.
Dec 06, 2015 | 1992 Suzuki Sidekick
I turned off my sidekick lx 2009 (off button) and it wont turn on
what i did was take out my sim charg it den cut it on it will cut on put sim bak in afta u cut it off and try again do a couple of time it will work
May 04, 2010 | T-Mobile Sidekick® 3 Cellular Phone
My 95 lumina 3.1 wont crank
ok heres some thing to check! u need a second person to do this!and a light tester! apply e brakes !locate starter motor ! it will be on the front of the front of the engine! there will be a small wire on it color pink or purple! with the second person in the drivers seat! u must connect the light tester to ground on the car ! as the person turns and hold the key in the start postion u must touch the light tester to the small wire! if u have positive power that the wire ! change the starter!
May 04, 2010 | 1995 Chevrolet Lumina
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sidekick LX screen goes blank/black
ok this is what you do take out the battery for ten seconds and then hold the w key and while holdinq the w key put in the battery and then let qo of the w key after the battery is putten and then turn you sidekick lx on and thennn it shoulf work aqainn :]
Aug 05, 2009 | Sharp Cell Phones
My sidekick 3! help me!
make sure your sidekick 3 is turned off completely then take the battery, sim card, and memory card out and lays them on the towel so they can get dries as well place your sidekick 3 in a big bowel with white rice in so they can absorb the wettness off of it and leave them all stay there for overnight or 2 days to let them dries and after 2 days up, put everything back in and turn your sidekick on and see if its worked again.
good luck.
p.s if its not working, then your sol and started to save up some money once again. or you can try and sell it for repair and parts on ebay or another websites and use that money to get yourself another sidekick 3 or wait for a new sidekick to come out that has been talking about it for a while is called a sidekick blade if you havent already heard about it. so yeah. its suppposed to be launch around in summer or fall then use that money for it, if you perfers that or you can go ahead and find a cheaper sidekick 3 around on ebay or you can check on CL(craiglist) to see if they have some with in a good condition for cheap. but, also make sure theyre not scam you for money or give you a fake advertise about it that they dont really have it. (just give you a lil heads up).
Mar 08, 2009 | T-Mobile Sidekick II
Sidekick wont turn on
that happened to me before.
all u have to do is take ur sim and battery out and then wait for 5 minutes and re enter them into ur phone...!
Oct 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 charging problems
Ok, is the sidekick 3 brand new out of the box or new to you.
The sidekick 3 has an issue with the charging port being bad.
I would contact the person who you bought it from and get a refund.
The other option is to get an external battery charger and charge the battery that way
check the link below for those
Sidekick 3 external battery charger cradle
Jun 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Help!!!
Changing your mail name from your Sidekick
To change your mail name from your Sidekick, perform the following steps:
1. From your mailbox, press Menu.
2. Select Settings.
3. Select Accounts.
4. Next to the account you wish to change, select Edit.
5. In the From Name field, type your new mail name.
NOTE: You can also change the From Address, Reply-To Name, and Reply-To Address from this screen.
Changing your mail name from the desktop interface on your computer
To change your mail name from the desktop interface on your computer, perform the following steps:
1. From the Sidekick desktop interface on your computer, select Settings.
2. Select General.
NOTE: From the General tab, you can change your name, time zone, or other personalized information.
3. In the name text box, type your new mail name.
NOTE: Changes made using the desktop interface will be transferred wirelessly to your Sidekick the next time you connect.
I have found this information from http://support.t-mobile.com/knowbase/root/public/tm20279.htm?A2L.SERVICE=How%20To
Nov 29, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Wrong charger, sidekick wont turn on
yea the samething happend to me and i had to go and get it fix there nothing to do just go and fix it. you welcome, Ricardo
May 19, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick® 3 Cellular Phone Logo
352 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
