Question about Canon PowerShot SD1000 Digital Camera
Images I seem to get yellowish images and images that are really dark even when I put the flash on. The flash seems weak, almost defected. But then in the next series of shots it will work and the picture will come out just fine. All of this in the same setting with the same subject and everything else a constant too.  Help please, it seems like I must be doing something wrong either that or my camera is broken. P.S. it is brand new Amber
No that isn't it but I am not offended. The flash in fact looks like it goes off but at 10% of the full strength. I had other people try to take a picture to see if the same thing happened to them and it did and I saw them, they did not have their hands over the flash.
Anymore suggestions?
Thanks,
Amber
Posted on Mar 13, 2008
  • Canon Master
  • 4,738 Answers
Please don't take offense, but the following should logically be tried first. Notice that the location of the flash is very close to where most people would hold the camera. Try taking some photos, but pay attention to where you would naturally place your fingers. Was it near or over the flash? If so conciously try to keep them away from the flash and then compare your pictures. Has the problem been corrected?
  • CameraR
    CameraR Mar 13, 2008
    Amber, your camera is relatively new. If less than a year old Canon should repair this for free under warranty. Here's the warranty for your camera, and recommend calling them directly at 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666):
    http://www.usa.canon.com/consumer/contro...
    Also just noticed that you're not the only one apparently having problems with the SD1000 flash. Usually Canon is very helpful and will make it easy for you to ship back your camera for warranty repair. Bring the following up with the Canon rep only if they are not helpful or if your camera is out of warranty (this could be a common defect with your model that they might be willing to repair regardless of warranty):
    http://www.fixya.com/support/t383085-fla...
Hi. I have a digital video camcorder. During the day I can take videos of my family and can see everything quite clearly but When its dark outside and I have to put on the lights I can't see details.
Your camera may not have enough light gathering capability to obtain usable images in the dark or the lens isn't fast enough. it really hard to tell when you haven't posted your model.
Nov 22, 2014 | Cameras
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
How do I turn on the flash?
If the flash even does to fire, while the camera is on automatic and it is a dark scene, you have to fear the flash is defect.
Jul 03, 2014 | Nikon Coolpix L1 Digital Camera
Dark images
your imager is going bad. need to send in to canon usually flat rate applies. worth the money to fix
Jul 07, 2009 | Cameras
Problem with dark LCD screen and accessing the the LCD ribbon that I think is loose
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 10, 2009 | HP Pavilion dv1010us Notebook
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Black image
ig you see an image but its just too dark, try adjusting the settings of brightness and contrast including lighting on the room.
Jan 16, 2008 | Philips J44414
Canon eos 300d - image to dark
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Jan 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
LCD display has a yellowish tint
This is a defective CCD problem known to Sony. They will replace it free of charge and even pay for the shipping. For more details go here for the link: http://www.imaging-resource.com/badccds.html
Dec 04, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Canon PowerShot SD1000 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
