How do I unlock this. My husband used to do this and he recently passed away and I have no idea. Thanks!
TRY UNPLUGGING THE DRYER OR DISCONNECT POWER BY TURNING OFF THE BREAKER. LET IT SET FOR 5 MINUTES OR MORE. THEN, REAPPLY POWER AND SEE IF THE MICROCOMPUTER RESETS. IF NOT, LOOK AT THE CONTROL FOR A LITTLE LOCK SIGN. SOME CONTROLS HAVE A CHILD LOCK FEATURE THAT LOCKS THE CONTROL AND HOLDING THAT BUTTON FOR 5 SECONDS WILL LOCK/UNLOCK THE CONTROL. IF YOU CAN'T FIND IT, TRY STARTING AT THE LEFT SIDE AND PRESS EACH BUTTON, ONE AT A TIME, FOR 5 SECONDS TO SEE IF ONE WILL UNLOCK THE CONTROL. IF YOU FIND IT, WRITE IT DOWN FOR FUTURE REFERENCE.
Posted on Apr 08, 2008
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
Driver door lock switch
Front passenger door lock switch
Door lock actuators in each of the doors
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
Driver Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
May 01, 2016 | 2003 Hyundai Sonata
Oct 02, 2015 | Philips Computers & Internet
May 28, 2011 | 2003 Volkswagen Passat
Apr 06, 2011 | Home Health Pacesaver Boss 6 Series Heavy...
Mar 09, 2011 | 2009 Chevrolet Impala
Oct 01, 2010 | Cell Phones
Apr 10, 2009 | 2002 Chevrolet TrailBlazer
Apr 26, 2008 | Sony Ericsson Walkman W810i Cellular Phone
65 people viewed this question
