I just put a Dsl wireless card in my compaq and now i can't get it to become active, it comes on and so does the monitor but the monitor light is amber and the power light is the only thing that comes on on the tower,could you please tell me what to do.. I have unpluged the cords on both things and left them off for almost an hr> and checked all cords and they are all intact.. Thank you
  • 1 more comment
  • mjwitmer Mar 12, 2008
    YEs Its a desk top..Its a Wireless-G PCI Adapter for high speed internet. The name of it is Linksys. I have to have it in my 2nd computer so I can get on high speed. hope this helps you
  • mjwitmer Mar 13, 2008
    I Tried what you told me. I took the wireless card out and still have the same problem, Do you have any other suggestions?
  • Raymond Roque
    Raymond Roque May 11, 2010
    Please specify the device that you installed in your COMPAQ. Is the COMPAQ your desktop?
    Sergeant:
  • 349 Answers
Remove the wireless card ,it may not be compatible,so look for an alternative.
good luck
Terry
Posted on Mar 13, 2008
  • terry Mar 13, 2008
    go back into the pc make sure you earth yourself first, by touching the metal casing of the pc,and check ever connection their is, as you may have moved something by accident
    • all cables both power and data ribbons to motherboard & to the drives,give them a push to make sure they are seated correctly
    • make sure no cables are interfering with the cpu fan
    • push down on the memory sticks
    • push down on any video card installed
    • push down on any other card that is in the pc
    if nothing improves obtain a boot disc and see if the pc will boot up of it,you may need to go into the Bios so that the pc will boot up of the floppy .usualy pressing delete key when booting up will get you into the Bios . but look on the screen when booting up to see what key to push.
    if it boot up of the flopppy it is a hard drive problem either it has the system files corrupted which mean you need to either recover the pc from a recovery partition on the hard drive or it has died and needs replacing.
    good luck with that
    Terry
    it may be that you zapped the motherboard with static electricity and killed it when you installed the wireless card .
    a last thought hit F8 when you turn on the pc ,it may boot into safe mode ,if you are lucky and it does ,use the restore function in windows to an earlier date.
    if my comments are worthy please rate them
    cheers
Monitor wont come on the power button light turns from green to orange and nothing on the screen
check your display card .. remove the memory ..clean the contacts and put it back.
Aug 30, 2014 | Compaq Computers & Internet
I have a compaq presario F500 and it wont connect to the wireless router. The light remains orange even when i activate the "blue light switch" on the front of the laptop. I have just installed a new...
More than likely. Especially if you bought the new card from a different company than the one that made your machine. Look on the card for model info, and google "(#model) wireless driver download".
May 20, 2010 | Compaq Network adapter
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am unable to set up wireless.
You should be able to go into Control Panel -> Network and Sharing Center and select Setup a connection or network to bring up a wizard that will guide you through the process of setting up your wireless connection.
Apr 14, 2009 | Compaq Computers & Internet
Front panel lights
you shoul also have a wireless icon on the x6. if someone is using your wirless link and you are not. the wireless icon should be flashing.
if you don't have the wirelss icon, then you have to have software to monitor the modem activity.
Oct 10, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Actiontec (GT704WG) Wireless Router Lights
Yes, this is normal. The flickering lights are showing activity - data is being transferred when the light is on, and vice versa. The power light should always be on when the unit has power. The DSL light should be solid as long as your DSL line is connected properly.
Jun 08, 2008 | Computers & Internet
Quick Question regarding a set up
correct you only need a wireless card or usb adapter is it a laptop or desk top unit? in any case a wireless adapter should do just fine
May 04, 2008 | Linksys Wireless-G WRT54G Router
Network card
Any type of PCMCIA network card should work okay.
Go down to Staples, Best Buy or Office Depot and find
a decent PCMCIA network card.  You should be able to find
one for under $50
Mike
Oct 29, 2007 | Compaq Armada E500 Notebook
No pic on my monitor
if you take the cover off your pc and look to where your monitor connects to the back of it you should find the video card
May 05, 2007 | Compaq Presario 700 Series DVD-Rom Drive...
Computers & Internet Logo
David Payne
David Payne
