Check the steam holes at bottom to see if holes is pluged with caculm build up that plug holes. To clean holes us calcum cleaner. Use decression . Use distalled water. Not tap water. There is probably a float inside of tank. Deposit calcum probably has stuck it. This is dependent on the brand and how old it is.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
