Question about Cameras
Can I use the Canopus Twin Pact 100 to transfer vider from digital video camera to computer? The firewire port on the camera is no longer working, so I need another way to transfer the video to the computer. Thanks .... Claire
  • armistead Mar 12, 2008
    Thanks very much for your prompt response. The video camera does have an S-video port, and video/audio ports (yellow/white/red). Would either of these work? I've already tried this connection to no avail, but I may have it hooked up incorrectly. The computer recognizes the Canopus device but not the camera.
    Any other alternatives? I've just about decided I'll have to buy another digital video camera just for the firewire port!!
    Thanks again for your help,
    Claire
    Thanks very much for your reply. The camera stores video on a mini-dv tape. I'm afraid you're right about difficulties replacing the camera's firewire port - it would probably cost more for repair and shipping than to just buy another camera that uses mini-dv tape!
    Thanks,
    Claire
  • 4,102 Answers
Hi im sorry to tell you but the only way is through the fire wire you cant even get it repaired as their is know where that survices them the only chance you have of converting it onto your computer is replace the canopus.
What does your digital video camera use to store its data on is it memory card let me know then i can assist you further
Posted on Mar 12, 2008
  • paul proctor Mar 12, 2008
    If you video camera has a card then you can buy card readers that work through the usb port these are cheap to buy and worth having as most new cameras have memory cards so it is worth buying as you will know doubt be needing it in the future
    Also most camera's and video camera's should have a lead that plugs into the usb port you usually get these free when you buy the camera but a card reader is probably your best bet unless you have the leads as mattozan sugests have a look if not check your video camera and see what it uses to store what you record
    Master:
  • 555 Answers
No, it isn't really the right tool for the job.
The Canopus is for converting analog video signals to digital (like capturing the video from your computer monitor as you move the mouse around).
You already have a digital video source (your digital video camera). So this box won't accept that as input.
If your video camera has other output ports, like component video (see below for a picture), then it might work. The Canopus will accept analog RCA for input.
  • Matt Jurach
    Matt Jurach Mar 12, 2008
    Hmm, yes, the S-Video should work with the Canopus.
    Your computer won't detect the camera when it is plugged into the Canopus. You'll have to use the Canopus to transfer the video onto the computer.
    It won't be optimal, since you'll be going from digital to analog and back to digital, but the Canopus is very good and the result should be very good as well.
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Please tell me from where i can download DCR-TRV285E driver of sony digital 8 .
If you mean a driver to transfer the video to your computer via firewire (ieee1394), then you are in luck! No driver is needed. As long as you have a correctly installed firewire port on your computer, a firewire connecting cable, and video editing software, you should be able to easily transfer video to your system.
Connect the camera to the computer via the firewire cable.
Turn on the camera.
Put the camera in playback mode.
Startup Windows Movie Maker or iMovie if on a Mac or whatever video program you prefer.
Should be an option for "capture" or "import from camera".
Use that and you are good to go!
Dec 13, 2010 | Sony DCR-TRV285E Digital-8 Digital...
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
Hooking my Sony Tr517 to my computer
You have to buy an audio-video converter like Canopus ADVC-100.
Check here: http://dv411.com/canopusadvc100.html
Nov 09, 2008 | Sony Handycam CCD-TR517 Camcorder
I have a twin pact 100 connected via RGB to mobile ultrasound unit.
Please check the videosettings on the ultrasound scanner.
(Videosettings)
Maybe this is for your purposes not correctly setup.
Think of : video interlacing, Frame/Filed, NTSC/PAL.
Ofcourse the same thing counts for the Twin Pact !
Question: what type is the Ultrasound Unit ?
Brand/Model ?
Oct 31, 2008 | Canopus TwinPact 100 (77010136100) Video...
XL 1s playback has a lot of digital noise.
if you are capturein through the fire wire port, it could be either the port is bad or the cable ha abad connection in it. try using a different cablr first, if that does not fix it, then it must be the firewire port. just to make sure, see if you can get ahold of a "Blue Box" one of those analog to firewire converter boxes, and see if it comes out clear then. if it does then I am 100% sure that it is the firewire port.
Feb 24, 2008 | Canon XL1S Mini DV Digital Camcorder
Transfer video from tape to computer
mjtlj:
You will need a firewire cable to successfully transfer video from your tape to your computer. It also greatly helps to have a firewire port on your computer. Once you have connected your firewire port on your camera to the firewire port on your computer, you can use windows movie maker to transfer video to your computer. (File > Import for Digital Video Camera)
If this has helped you, please report this problem as fixed :)
Jan 08, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Canon ZR85 video to pc transfer problem
Better Late than never....
The usb port is for the memory card only....You will need a firewire to transfer over the DV tape.
Aug 18, 2007 | Canon ZR85 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
