Question about LG LRSC21935 Side by Side Refrigerator
Trying to change LG side-by-side fridge filter
We are trying to change the filter but the old one won't come out. Have read instructions and turned it to the unlock position to pull down, and tried every step in between unlock and lock, but it just won't budge!! Any ideas?
I have a whirlpool ed5fexnb01 it says to rotate the re-usable **** 90 degrees but it wont budge i have tried everything but it wont budge
I used a strip of Duck Tape to make a handel. Just stick it to the sides with a loop at the bottom. This will allow you to pull with more force...
WARNING, dont break it! I have a small leak now. I have removed the two screws to access the whole receptical that holds the filter. It now leaks a few drops on the left side when water is dispensing or filling ice tray. I need to find a replacement now.
Posted on Sep 11, 2008
    President:
  • LG Master
  • 2,651 Answers
Try removing hte kick plate first. and slightly push in as you turn counter clockwise 90 degrees. it'll come. ive hadsome stick but never break on me
Posted on Mar 13, 2008
LG side by side model# lsc26905tt, won't dispense water. I can hear the pump trying to pull water but the water is sitting in water line just outside of filter on the outside of fridge.
Sounds like the dual solenoid water control vave. Located in the back it will have two wire connectors going to solenoids. They are replaced as a pair and most local appliance dealers have universal replacemants. http://www.lg.com/us/refrigerators/lg-LSC26905TT-side-by-side-refrigerator
May 31, 2015 | LG Refrigerators
Ice smells bad
You can leave the fridge turned on but make sure you shut off the water and put a container under the filter when you remove is as there will be water that will try to go everywhere. Any filters are external so if you had to add one there won't be any others to change, Make sure you flush the new filter to the instructions when it is replaced.
Mar 07, 2012 | Refrigerators
I am trying to change my water filter for my viking fridge. I have removed the unit from the base of the fridge, but cannot seem to get the cap off of the unit to instal the new filter. The instructions...
When you turn it counterclockwise it will stop. then.. oops is the water off? then once it stops pull down on it and it will release from the head.Reverse procedure to install.
May 11, 2017 | Viking Refrigerators
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
LG Side by Side - replaced filter now ice/ water will not worl
See if it works when you pull the filter out and try running it (without the filter in). If it works, try buying a new filter and make sure you have the filter that is made for your specific refrigerator. If no water comes out or no ice is made after pulling filter out, than you probably have a obstruction in the line. If thats the case you should have someone come out to fix it. If your mechanically inclined you can try to do it yourself. I would suggest reading the owners manual first, in the "troubleshooting" section.
Aug 05, 2009 | LG LSC26905TT Side by Side Refrigerator
Water Filter removal/installation
Bought the filter replacement and read the instructions. Turn off ice maker and replace filter. Remove by turning 1/4 turn to the right. pull out old filter. Remove cover, slide off, replace cover by sliding on the new filter. Push new filter in to the holding, hold so cover is horizontal, push in and turn back clockwise till the cover is horizontal to the floor.
Feb 02, 2009 | Whirlpool GS6NBEXR Side by Side...
How do i remove the water filter
The filter will come out attached to the cover .. look inside the cavity . there should be a space there for the filter .. the ones at the top of the fridge are quite small compared to the ones that go at the bottom on some fridges. Most appliance or building supply stores will have replacement filters on hand .. have your make and model number to get the correct replacement., or the old filter ..
Feb 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Nov 24, 2008 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
LG LRSC21935 Side by Side Refrigerator Logo
261 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
