Question about T-Mobile MDA
T mobile MDA
What are soldered contacts? are they inside the phone and are they easy to fix?
  • 113 Answers
There are screws underneath the battery, underneath the antennae and some stickers. once all of those are removed use a screw driver to slightly open the case. Go to youtube.com and check out how to solder. Don't get a cheap soldering gun you will need an expensive one to get it done right. You need one with a small tip. they are not easy to fix but they can be fixed.
Posted on Mar 14, 2008
SOURCE:
The part where the mda charges is loose can it be fixed i have some old info on it.
The part will need to be re soldered in place or replaced all together. I recommend finding a parts unit on ebay and doing a swap out of boards.
May 04, 2010 | T-Mobile MDA
Unlocking my mda phone
go to www.xdadevelopers.com website they have small program very easy to solve your password problems
Apr 22, 2008 | T-Mobile MDA
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
Tmobile MDA factory default message
It would seem he water has coroded the keyboard contacts. You could carry it to a servicenter and ket the keyboard contacts cleaned
Oct 18, 2007 | T-Mobile MDA
MDA phone screen is scrambled with Lines
Marc1234: sounds like the backlight is out......possibly a software malfunction.....try goign to www.t-mobile.com/wmuprade to reinstall the software....if that doesnt work, contact htc or your service provider....you will need a replacement. if youre out of warrenty, it will be a lost cause....
Guest,: your USB port is broken, if you dont fix it yourself, you will need another phone.
Oct 17, 2007 | T-Mobile MDA
T Mobile MDA Speaker control
Update teh firmware from tmobiles website. Download the latest firmware and upload it to your mda... Should fix it.
Aug 01, 2007 | T-Mobile MDA
Usb sync charger broken on 2nd mda in 6 mos.
I'm dealing with the same problem overher in Holland. I'm looking for someone to "weld" the contacts. But you sould take a look at this website perhaps they can help you. http://www.pocketpctechs.com/main.asp?unit=Qtek_9100-513&area=repairs
Dec 28, 2006 | T-Mobile MDA
T-Mobile MDA Logo
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
