Question about Dishwashers
My dishwasher blinks when I hit start but will not actually start. How do i check the door lock? It clicks when I close it, but I do not know how to check to see if in fact it is being registered as closing
  • 2 more comments
  • kalynns33 Mar 13, 2008
    Hi, I am not sure what the model number is, but the brand is Frigidaire. It was a very basic one, not very expensive if that helps
  • kalynns33 Mar 14, 2008
    I am not sure what you mean by: "if not the door latch comes as an assy cant replace just the switch"
  • betcostevek May 11, 2009
    My door seems to latch but the lock button flashes and when I push the start button nothing happens. Is there something I did to accidentally lock something up?
  • Ron Coons
    Ron Coons May 11, 2010
    who makes it and whats the model number???
    President:
  • 2,651 Answers
You would need to drop the front panel , the 2 lowest screws in inside of door drop the main colored panel. the remaining screws release the the control and give you acess to the door switches, with the panel off you should be able to close door and watch the latch in action. are the switches being activated??? if not the door latch comes as an assy cant replace just the switch
Posted on Mar 13, 2008
  • Ron Coons
    Ron Coons Mar 15, 2008
    if one of the door switches are no good , ou cant repalce a switch you would need to replace the whole latch assy
6ya staff
SOURCE:
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
-high temp wash
-heated dry
-high temp wash
-heated dry
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Blinking clean light
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher Troubleshooting
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
  • Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
  • All lights should illuminate then a diagnostic sequence will start.
  • Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
  • Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 23, 2008 | Kenmore Dishwashers
Clean light is blinking
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
