Tito I have an hp wireless optical mouse with p/n 5188-6926 that sudenly stop working, but the hp wireless keyboard is still working. I can turn on the muse, but when I use it the led on the usb receptor doesn't turn on.
HP wireless keyboard works fine, but the mouse stopped working even after buying new batteries. I have followed the directions in reinitializing the mouse, but still no luckHP wireless keyboard works fine, but the mouse stopped working even after buying new batteries. I have followed the directions in reinitializing the mouse, but still no luck
hp wireless keyboard still works - mouse does not.
new batteries in mouse - it is turned on. The receiver is dongle type - its blue led blinks with keyboard use but not with mouse. yes, pressed connect button on mouse. there is no button on receiver. This is the peculiar part I first noticed a problem when I turned on the power to my Epson R260 usb printer which connects to another port. There was a error report that said one of the usb devices had failed and the mouse stopped working. I turned the printer off and fiddled with the mouse - pressing the button and rebooted. The mouse was working again until the next time I turned on the printer and the same thing happpened but this time the mouse was dead for good - even with the printer disconnected. Weird.hp wireless keyboard still works - mouse does not.
Mouse suddenly stops working - I then switch off the mouse and then switch it on again and it starts working for a while before I have to repeat the sequences. When working, the red light on the bottom of the mouse continually flickers indicating, perhaps a loose connection inside. Batteries are new.
Any thoughts?
BudMouse suddenly stops working - I then switch off the mouse and then switch it on again and it starts working for a while before I have to repeat the sequences. When working, the red light on the bottom of the mouse continually flickers indicating, perhaps a loose connection inside. Batteries are new.
Any thoughts?
Bud
AnonymousJan 30, 2009
my hp wireless mouse has just stopped working, the red light is still on and flikering and the keyboard works,,, whats wrong with it ?
AnonymousMar 08, 2009
the red light in my new h p wireless optical mouse is on, but the green light in the usb receiver is not and neither the cursor is moving nor is any thing working! tried sync but it did not work! and yes, the battery is full and the mouse is turned on!
the red light in my new h p wireless optical mouse is on, but the green light in the usb receiver is not and neither the cursor is moving nor is any thing working! tried resyncing but it did not work! and yes, the battery is full and the mouse is turned on!
You can't post conmments that contain an email address.
turn the mouse over, press and hold the tiny button on the bottom. At the same time - find the transmitter connected to your pc and press and hold the tiny button on it too and hold both buttons down for a few seconds. This will calibrate your mouse and return it to working order.
There should be a small place on the mouse to push in using the end of a straightened paper clip. this should reset the mouse to find the wireless emitter that goes with the mouse/keyboard.
The wireless emitter would have to be plugged to an electrical outlet or a surge protector.
go to following link from HP
and recheck things again..
if things still dont work then contact HP to get the mouse replaced..
http://tinyurl.com/y8ek43e let me know if this resolved ur issue.. regards,guru
You will need to "pair" it with the receiver. Look on the receiver and you will find a button. press it then press the button on the mouse.
Then wiggle the mouse around. You should see the pointer move.
Ref wireless mouse. Not sure if you have a solution yet but it seems there could be 2 sources to the problem. First a weak or decaying laser. Second, something you have introduced recently that could interfere with the wireless signal eg mobile phone, another wireless device, cordless phone, telephone wires close to receiver or maybe something else. Not sure what you do if the laser is failing other than clean the lens. You might have to get it checked or try a friends mouse to see if it is better. There s also a setting than can change the sensitivity of the mouse. Have you looked at those settings.
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
It suddenly stopped working :- (
I have the same probLem with my wireLess mouse ..
My keyboard works weLL ..
but this hp mouse stopeed working :S
same problem,but right click is working and left click is not working.
is this under warranty? i have less than a year
Any thoughts?
Bud
