Hi i use predictive texting on my sony ericsson k810i and every week or 2 weeks the words vanish from my dictionary and i have to install them all again...so annoying as it is a really easy way to text just fed up with re entering words...any clues?
It's limited to a certain amount of memory, when that's full, your dictionary is unable to expand.
"Time is what keeps things from happening all at once."
PS. I don't mean your phone memory. I mean the allocated memory for that function. IE. txts msgs will allow maybe 20 to be stored. Contacts will maybe allow 200.etc...
There are many things that come into play, for example if you send lots of Bluetooth files, no matter what they are, they leave dust files behind which don't always delete automatically. But they still take up memory space, so do installed applications etc...
You could also try a reset using the menu/restore to factory settings. Back-up your phone first.
However your phone might benefit from a software (firmware) upgrade via Sony Ericsson PC Suite. You can check if there's a newer version of software available for your phone, at the Sony Ericsson website. If you go for it read below:
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
ah right i see...thx anyway but my hubby got the same phone and his words stay in the my words category all the time so i dunno...i had a k800i for over a year b4 this phone and no probs with tht either
