Question about Kitchen Ranges
BEEPING F-1 FLASHING
HOW DO I GET THE F-1 TO STOP FLASHING AND SET THE CLOCK ON MY MAGIC CHEF GAS STOVE WITH AN ELECTRIC START THE MODEL NUMBER IS 3488XRB
Evidently there was a faulty part that caused a problem and it resulted in the F1 code showing up. There was a class action lawsuit and settlement. Check out this website... It tells all about it and maybe you can figure out if this is what your problem is.
http://www.ovensettlement.com/faq.php3
Posted on May 21, 2009
Magic Chef, F-1 code?
This might help... http://www.appliance411.com/archive/25036_magic_chef_f1_error_and_slow_to_heat.shtml
Jun 20, 2013 | Cooktops
C clock will not stop buzzing. 15 year old magic chef oven. do not know model number because manual does not identify it. the only thing I have is a number at the bottom of the installation manual. Not...
Beeping from ovens is an indication of function buttons in user. Observe the entire feature function either as cooker still in operationality where beeping is warning as haven been completely secured from functionality. Refer with an expert with condition over impressive.
Mar 01, 2011 | Magic Chef Ovens
I have an older magic chef I am trying to use the self cleaning feature. what am I supposed to have the two timer knobs set on? Or should I say the stop and start knob and the clock?
Start time should be set to current time of day (according to the clock on the stove) and the stop time should be set for at least two hours later. This will allow the timed oven feature to work for the self clean option.
***Keep in mind that if the clock does not work you will have to shut the oven off yourself after the two hours is up!!***
Good Luck!
Jun 15, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Feb 05, 2010 | Magic Chef 31000 Gas Kitchen Range
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
Hope it helps.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
214 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
