Question about Dishwashers
I can't find the data plate,sticker, on my Maytag dishwasher. Do they have another spot I could check for my model number?
    President:
  • 2,651 Answers
Should be on the inside lip of the tub assy either to the left of the latch or along the left side mounted vertically just infront of the tub gasket assy
Posted on Mar 13, 2008
Replacing Maytag dishwasher model #MDB6650AWB. What is the decibel level of this model? i'm looking for one quieter one
Hello. I couldn't find the exact data for the decibel level of this dishwasher but, here is a link to a comparison chart which shows the different models and features. Maytag Jetclean Dishwasher I hope this helps you!
Oct 02, 2015 | Maytag Dishwashers
Tip
Maytag Dishwasher Recall.
Hi.
Maytag issued a voluntary recall for nearly two millions dishwashers after getting a number of reports of dishwasher heating element failures that resulted in fires and dishwasher damage.
Check your dishwasher model number, then give Maytag a call to find out if your appliance is listed in the recall notice.
The recall is affecting all models with number starting with:
NW39, NW40, NW41, NW42, NW43, NW44, NW45,
NW46, NW47, NW48, NW49, NW50, NW51, NW52,
NY01, NY02, NY03, NY04, NY05, NY06, NY07,
NY08, NY09, NY10, NY11, NY12, NY13, NY14,
NY15, NY16, NY17, NY18, NY19
And models with number ending in:
JC, JE, JG, JJ, JL, JN, JP, JR, JT, JV, JX, LA, LC, LE, LG, LJ, LL, LN, LP, LR, LT, LV, LX, NA, NC, NE, NG, NJ, NL, NN, NP, NR
You can also click here to check if your appliance is affected.
Click here for a video showing how to locate your serial number
If your model is affected contact Maytag or visit their website at www.repair.maytag.com.
To report an incident go to https://www.cpsc.gov/cgibin/incident.aspx.
on Jun 03, 2010 | Dishwashers
Where is my model number on my roper dishwasher locate?
The model numbers and other pertinent info is typically on the frame of the door. As you open the door check the area where the door seats. There should be a plate with your data on it. Best of luck.
Sep 27, 2014 | Dishwashers
Where do I find my model number on my Maytag range?
their have an sticker may be in steel where your model number and company name have.if no sticker then you can find it back side of maytag range.
May 30, 2014 | Maytag Ovens
Maytag dishwasher won't work. No light on control panel on door. I took the door off and can see a burnt spot on the circuit board. I was wanting to know where I could get a circuit board. If that...
Since you didn't give the model number, I would suggest you go to the searspartsdirect.com website and enter your model number (off the machine id tag) and look up the part on there.
NOTE: Sears is not the cheapest site, BUT they use the actual part number so once you find it on the Sears web site, you can do a search to find the cheapest source.
Aug 03, 2011 | Maytag Kitchen Ranges
Control Panel Problem on a Maytag DW MDBTT79AWW
I had this same problem, ordered the replacement control panel from whirlpool. The new panel worked for two weeks, then stopped working again. OUCH!
The replacement part costs $264.34 and has no warranty if you do it yourself.
I think I am now going shopping for something other than a Whirlpool or Maytag machine. They have terrible customer service.
Feb 12, 2010 | Maytag Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Philips Whirlpool Integrated Dishwasher
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Apr 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Racks corroding.
Check on Ebay. I just entered this to check for you. maytag dishwasher racks" and there were several on there. One was universal and could be used with 40 different model numbers.
Oct 25, 2007 | Maytag MDB9100A Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
