Question about Health & Beauty
Electric shaver Guidance on opening case up to check/replace battery
  • Anonymous Apr 19, 2008
    replacing bettery dont know how?
  • mjja Oct 12, 2008
    After removing the screw, how do I get the plastic case open on my R 960 Remington razor without breaking it? Is there a trick to releasing a tab or sliding it in a certain direction?
    Problem Solver:
  • 4 Answers
After removing the two screws on the bottom, use a 1/16" wide screwdriver at the (on/off switch side) of the large holes (not the actual screw holes) to pry the back case away. The cord receptacle is part of the front of the shaver and will go with it.
If you look carefully before prying apart you can see a relief to aid insertion of the small pry tool.
Posted on Feb 07, 2009
I HAVE A PHILLIPS SHAVER MODEL 5890 AND HAVE PURCHASED NEW RECHARGEABLE BATTERIES. HOW DOES ONE REMOVE THE OLD BATTERIES AND FIT THE NEW ? I HAVE OPENED UP THE SHAVER BUT THE EXISTING BATTERIES SEEM WELL...
The batteries are soldered into place. You will need a soldering iron and electrical solder to replace them. Unsolder the old batteries from the circuit board and solder in the new batteries
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See information at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 20, 2011 | Philips 7140XL Electric Shaver
I need Guidance on opening the case up to check/replace battery. This is a Remington WPG-250 and doesn't have any screws on the outside.
There are no screws holding this together only 8 locking plastic clipbs (4 on each side). To open I started near the battery charger end and used a flat tip screwdriver to gently pry open the case. Repeat on the other side. Unit has 2 Sanyo NIMH AAA batteries (welded tabs in series). I can't determine if these are regular NIMHs or enloops.
Aug 22, 2010 | Remington WPG-250 Hair Trimmer
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
How do I disassemble to replace battery?
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant).
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Nov 30, 2009 | Norelco ReflexPlus 6863 XL Electric Shaver
Battery needs replacement
Your shaver should also be a Mains shaver - if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 26, 2009 | Norelco Quadra 6846 XL Electric Shaver
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Feb 12, 2009 | Philips Philishave HQ7780 Electric Shaver
Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Health & Beauty Logo
1,191 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
