Question about Samsung ML 1210 Laser Printer
Slow to Print
I have a Samsung ML 1210, and it has given me good service. I'd buy another one.
It seems to take a long time to print once I send the copy to the printer. Like it is warming up. Then it prints a good copy. Most of my office printers respond pretty quickly, except this one. It is on all the time
I have a ML 1210 but I have not a XP driver
Posted on Mar 13, 2008
SOURCE:
I need download driver software from smsung prodcts so my printer shoud work,tk
Please go to this link http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1210.
Scroll down.
Under Products Support please click Universal Print Driver.
Scroll down a bit.
Under Downloads select your operating system.
Hope this helps.
Thanks
Jul 09, 2011 | Samsung ML 1210 Laser Printer
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
Jan 18, 2011 | Samsung ML 1210 Laser Printer
I successfully installed my ml-1210 on a new computer using the driver download, but it won't print the sample page, nor will it print the demo page when I push that little 2 second button on the printer. ...
did you do do a test print once you completed the install,go to printers and faxes in control panel right click on the printer select properties select print test page.if this print,close this right click on the printer again select use as default,this should take care of your printing problem.
Good luck
Aug 30, 2009 | Samsung ML 1210 Laser Printer
Randomly missing print spots just off center of page
this happens to myne all the time try cleaning all of the rolers and try a different brand of paper
Jan 07, 2009 | Samsung ML 1210 Laser Printer
I have a hp psc 1210 all in one,it is playing up with print outs, is it possible for me to replace the print head on this model Rick
HP printers use cartridges that ARE the print head. On occasion, the cartridge could be defective...especially if they are the remanufactured type. Try replacing your cartridge with a new HP cartridge.
May 29, 2008 | HP Office Equipment & Supplies
Compatable with Mac?
 Get the ESP Postscript and the Samsung GDI driver from linuxprinting.org and install the two. Go add a USB printer in the OSX print center, hold the option key to get to the “Advanced Options” and add a “Samsung” printer, chose the ML-1210 driver and you’re done.
here is the link for drivers above http://www.linux-foundation.org/en/OpenPrinting/MacOSX/samsung-gdi
Oct 16, 2007 | Samsung ML 1610 Laser Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Error msg
Hi Usually with this printer, you just simply turn it off and then on again and the lights will stop flashing. This is an LSU (Laser Scanner Unit) error. If you still have the problem, it might be either the LSU needs replacing or it could be the main board. These parts might be scarce though and very expensive. It might almost be cheaper to buy new printer but that is up to you to check and decide for yourself.
May 24, 2007 | Samsung ML 1210 Laser Printer
Samsung ML 1210 Laser Printer Logo
236 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
