Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP sp2 will not reflect the correct Daylight time.
My xp sp2 will not display the correct time if I select the "tijuana baja california time" zone. However, if I use the "pacific time" zone it shows the correct Daylight savings time. They both show GMT -8. Do you know why?
I have the MS daylight path installed.
  • 818 Answers
See this pag can be interesting for you.
Sergio
http://www.charter.com/customers/Support.aspx?SupportArticleID=1691
Posted on Mar 13, 2008
How do I reset the time on Garmin vivofit
You should synchronize your device to receive the correct time when you change time zones, and to update for daylight saving time.
  1. Confirm that your computer or mobile device displays the correct local time.
  2. Select an option: Synchronize your device to a computer (Sending Data to Your Computer).
v?vofit Owner's Manual - My device does not display the correct time
https://www8.garmin.com/.../vivofit/.../GUID-FF71ED02-BAE2-4992-BF85-661A5BF0
Nov 07, 2016 | Garmin GPS
Tip
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC...
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC to reflect the correct time when your local time is set*
According to Citizen's website FAQ, their watches cannot determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. If you are on the winter side of the time change (fall back), you'll have to go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) and in the spring change all of the appropriate timezones back to ON (for summer time). Disappointing, I know... for an otherwise great watch this would be my one complaint.
on Nov 17, 2011 | Citizen Watches
I need a zip code in mexico
No secific area in Mexico? Here are some in Baja Califonia, Mexico
21389 Mexicali, Col. Hidalgo 21395 Mexicali, Col. Elias Calles 22000 Tijuana, Zona Centro 22127 Tijuana, Inf. Lomas verdes. 22440 Tijuana, Col. 20 de Noviembre 22200 Playas de Tijuana 22444 Tijuana, Cd. Industrial 22650 Tijuana, La Floresta
Hope this helps.
Sep 19, 2011 | Computers & Internet
How do you set the time on a c340?
Question: The time is not correct on my StreetPilot. How do I set it?
I think one of these 2 may help you.... --> Answer: The GPS unit acquires the time from satellites. Therefore, to display the correct time, the StreetPilot first needs to acquire satellites. You can then set the time zone and daylight savings time.
To set the time zone and daylight savings time:
  1. Press the Menu button two times.
  2. Select System Setup.
  3. Select the Time tab.
  4. Select the time zone and daylight savings preference.
Oct 23, 2010 | Garmin StreetPilot c340 GPS Receiver
The time on my gps 1440 is 1 hour fast?
To switch between Daylight Saving Time - on or off:
1) Turn on unit - Press the picture of the wrench and screwdriver at the bottom.
2) At the next page, select "System"
3) At the next page, select "Time Zone"
4) Select "Daylight Savings Time" at the bottom to toggle it on or off
Jan 08, 2010 | Magellan RoadMate 1440 Car GPS Receiver
How do i change the time setting on my magellan 1440 gps
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go to the main menu, then system option and click on the time zone tab, then select your time zone and check off the little box for daylight saving time.
bill
Dec 06, 2009 | Magellan RoadMate 1440 Car GPS Receiver
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Date and time change
It appears that you have the wrong time zone setup. Right click on the time in the taskbar, select Adjust Date/Time.
Make sure the time zone is set for your location.
Lou
Sep 16, 2008 | Microsoft Windows XP Professional
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Clock and calander on Win 98 won't keep proper time or date
2 possible solutions
1. Replace the CMOS battery that is on your motherboard.
2. The time zone you have set may not be correct. Please read microsofts article below:
Thanks to the Energy Policy act of 2005, we live in an age where the Federal Government has decided to change even time once again.
Here are the settings for the new daylight savings time that begins in calendar year 2007:
Current (2006 and before) daylight savings:
Daylight savings starts at 2:00 A.M. on 04/02/06 (first Sunday in April)
Daylight savings ends at 2:00 A.M. on 10/29/06 (last Sunday in October)
2007 Daylight savings:
Daylight savings starts at 2:00 A.M. on 03/11/07 (second Sunday in March)
Daylight Savings ends at 2:00 A.M. on 11/04/07 (first Sunday in November)
Microsoft released an update for the change in Daylight Saving Time (DST) that goes into affect next spring in the United States due to the Energy Policy Act of 2005. The update also addresses some changes in other time zones. The update will be included on Microsoft Update, Automatic Update and WSUS starting December 12, 2006 for Windows 2003 and Windows XP. Windows Vista will already include the newer time zone data.
That’s nice for folks running Windows XP, Windows server 2003, or who are about to purchase Vista. What about the rest of us? Microsoft has provided a knowledge base article KB#914387 to cover the subject. I’ve read it and understand it, but I seriously doubt it will be much help for the average user, or a number of IT professionals either, for that matter. Windows 2000 Professional is already in extended support, and Microsoft no longer supports any of their earlier operating systems. If you are running one of these earlier systems (like I am), you probably figure you will have to manually change your computer clock twice a year starting in 2007. That’s not necessarily true.
There is a way that the average user can handle this situation and still have the computer automatically change time for daylight savings. The method involves downloading and installing two very small free programs in your computer. It will work with Windows 95, Windows 98, Windows ME, Windows NT 4.0, Windows 2000, Windows XP, and Windows 2003(server). Here are the steps to follow: 1. Open your browser and go to:
http://www.karenware.com/powertools/powertools.asp
2. Scroll down until you find the program named ‘Zone Manager’, and left click on it.
3. Scroll down to ‘Download’ and download Zone Manager and save it to your hard drive (a folder named ‘downloads’ might be a good place) in a location you can easily remember. If you do not already have Visual Basic Runtime v 6.0 installed on your system (you will need it to run Zone Manager) you can also download and save it to the same location on your hard drive from this same page.
4. Close your browser.
5. Be sure you are logged on as an administrator privilege account if your system requires it to install programs.
6. Open and install Visual Basic Runtime v 6.0 on your system (if you already have VB 6.0 installed on your system, ignore this step). Reboot your computer.
7. Open and install Zone Manager on your system.
8. Reboot your computer.
9. Go to Start | Programs | Karen’s Power Tools, and select Zone Manager by left clicking your mouse.
10. On the lower left of the page, left click the button named ‘Edit Zones’.
11. Under the tab for Windows Built-in Time Zones, find your local time zone and left click on it to display the built in Windows settings.
12. Left click the ‘New Zone’ button to create your new custom time zone, type in what you want for a name, and be sure the box is checked to ‘Enable Daylight Savings Time’. Set ‘begins’ for the second Sunday in March, and set ‘ends’ for the first Sunday in November.
13. Review your settings to be sure they are correct, and then left click the ‘Save Zone’ button, followed by the ‘Save All Changes and Close’ button.
14. You should now be back on the main program page. Here, you left click the ‘Save Shortcut to Zone’ button followed by the ‘Exit’ button.
15. You now have a new desktop icon labeled ‘Activate…..’ that looks like a red box with a white K in the middle of it. When you double left click it with your mouse, your computer will be changed over to the new custom time zone you created.
If you followed the instructions above, you now have installed your new custom time zone that will change your computer time for you in 2007 to accommodate the new Daylight Savings Time settings. You will have spent about 15 or 20 minutes, and you didn’t even need to become a programmer.
If the government ever decides to change things again (They wouldn’t ever do that again now would they?), you just open the Zone Manager program again, create a new custom time zone with the proper settings following the steps above, and delete the old custom time zone.
If you like the Zone Manager program and play around with it a bit, you will find it also has a time synchronization feature that will allow you to synchronize your computer clock with one of the precise atomic clock servers around the world. You left click on the ‘Set Time’ button on the main program page, select the time-server near your current location from the new page that opens, and then left click the ‘Synchronize’ button on the upper right. It should only take about a minute or less even on a dial up connection.
Aug 05, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
