I have problem with delphi. Delphi5 doesn't run under the non administrator user
  • julezxc Mar 13, 2008
    No thet doesn't help. Students have to be loged as users, no as administrators.
  • 99 Answers
You have to change your account,make it an administrators,go to control panel open user accounts,click your accounts,click properties,click group membership,click other,then choice administrators,then ok
Posted on Mar 12, 2008
  • jose obrero
    jose obrero Mar 13, 2008
    ok,try to check the setting of your anti-virus ,may its blocled,make it full access in the settings
I downloaded mozilla firefox 5.0 and 6.0 but after i run it i keep being prompted that i dont have the necessary permissions to use all the programs and then the last sentence say that you may run this...
Depending on your Operating System, you may need to run it as an administrator. If you're on Windows, right click on the setup executable file and click Run as administrator. If that doesn't show up, click Run As and click administrator.
If you're on Ubuntu open up terminal, cd to your directory and write sudo firefoxinstall(or whatever your setup name is).exe
For example:
sudo firefox5.01setup.exe
Have fun :)
Aug 21, 2011 | Computers & Internet
Can I use my Borland Delphi 5 CD for installing Delphi 5 on my new Windows 7 computer
This is the last version of Borland dBASE for Windows (next version is Visual dBASE 5.5).
This is VERY unlikely to work as it was designed for much earlier operating systems.
Windows 7 is a very different architecture - maybe it time to upgrade.
Mar 10, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
I can't log in as it keeps coming up user profile can not be loaded, please help
try and log in as administrator, create a new profile under control panel>Users. name it whatever you would like, then manually copy the contents of the old user libraries to the new one. so basically let's say your old user was named 'fail' and your new user is named 'win' after creating win, go into windows explorer, and go to c:/Users/fail/libraries and hit copy. navigate to the same location in win's directory and hit paste. it will ask to replace files that are already there, go ahead and hit yes. if you can't log in as administrator you may be able to tap f8 @ boot until you get to a boot menu and then arrow down to 'repair my computer' once loaded it will probably try and run startup recovery. if this doesn't fix it, you'll be presented with another grey menu. click dos prompt. once dos prompt opens type cd c: then type chkdsk c: /r that should fix the file structure. you can also run sfc /scannow which will check your system files. good luck!!
Jan 16, 2011 | Acer Aspire 5535-5050 Notebook
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
I installed ScanSnap on Windows 7 under the administrator account and it works successfully. The problem is with the other non-administrator account. The ScanSnap icon was not installed on the...
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Mar 21, 2010 | Fujitsu ScanSnap Manager
User password frozen windows 7 when i boot the PC it requires the password but then opens to a non-registered user who can't save any documents and who has no access to my own files
Try this, 1. Open a elevated command prompt. Click on All Programs and Accessories, then right click on Command Prompt and click on Run as administrator.
2. To Enable the Hidden Built-In Administrator Account -
A) In the elevated command prompt, type net user administrator /active:yes and press Enter.
3. To Disable the Hidden Built-In Administrator Account - A) In the elevated command prompt, type net user administrator /active:no and press Enter.
4. Close the elevated command prompt.
5. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen
Feb 07, 2010 | Acer Aspire 5500 5570-2609 Laptop
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
I'm trying to adjust the power management options on my XP pro Compaq Presario. I can change the options when using my administrator account, but those changes don't seem to become effective for the other...
try setting the power management options in the BIOS(hardware based, access it by pressinfg DEL or F2 or F1 when booting,)
instead of using the windows feature.
settings once made as an admin in windows should be available for all users, else just leave the name for the user but upgrade the user status from power user or guest status to admin, enter changes, reboot, logon with old name, downgrade account from admin to user or whatsoever, that might do the trick...
good luck
Sep 01, 2009 | Compaq Presario 5000 PC Desktop
Lost user account
You actually probably created the new account as an admin. You don't really need to recover it. You just use this account as your admin account. You can then create another non admin account now and have everyone else besides the "admin" likely being you, can use the non admin account. All your files can still be found in "rootdrive:\Documents and settings\administrator
There you can find all your documents that you had in My documents under the administrator account.
Hope this helps,
Midwest
Sep 24, 2008 | Microsoft Windows XP Professional With...
Vista Compatability is zero
I was able to install under a user account with administrator, although some features are not enabled or working properly for other non-administrator users.
Jul 26, 2008 | Singer CE-200 Quantum Futura Computerized...
Computers & Internet Logo
David Payne
David Payne
