Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Security question I have a westell versalink 327 w wireless router and I believe my neighbors are using my internet access. How can I lock it down to stop them?
Get the ip config information using either the command prompt from the windows accessories programs menu using the command: ipconfig/all. You will need two sets of numbers from this readout: Your physical address and the default gateway.
Open the modem from your browser using the default gateway numbers given.
Once on the modem webpage establish your administrative name and password. If the first time try using "admin" for ID and "password" for password then assign a new one for your use only.
Go to wireless options section, security option. Turn on the wireless function if you want ifand establish the level of encryption you want, usually 128K. If you go higher remember the info being sent will be broken up into more packages therefore slowing the transfer process. Establish a password as directed by the written text, usually 12-14 hexadecimal for the 128K level. Though you might be told to use either all numbers or letters the best passwords are a combo of both with special symbols. For instance you might pick a sentence to remember "The cow jumped over the moon." The password might look something like [email protected]
Once you've established an encrypted modem then enter the password into your properties menu for the LAN connection on your computer. Find this in the control panels under network connections. This should be enough to eliminate the problem. The next bit of advice I'll give will hide your modem from snoopers and secure it within your home or network to only those computers you want on it.
Go to CNet or PCWorld for more in depth security involving the enabling and use of MAC addresses. Very important and the real security your computer needs. Good luck.
Posted on Mar 17, 2008
    Scholar:
  • 141 Answers
You can set up your WIRELESS SECURITY SETTINGS.
Open DOS Prompt, on the black screen type ipconfig, then click enter. Look for default gateway(it will look like this----192.168.1.x
Open your Internet Explorer, type the 192.168.1.x then click enter. This will take you to the configuration page. Click on CONFIGURATION, then click WIRELESS. Set up your security. Make sure you take note of your settings OR ELSE YOU WILL NOT BE ABLE TO CONNECT TO YOUR WIRELESS NETWORK ALSO BECAUSE OF THE SECURITY THAT YOU SET UP.
Posted on Mar 14, 2008
SOURCE:
I added a security code on my Westell 327 for my wireless network but now my remote computer cannot connect to the wireless network. Do I need to reconfigure the router?
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jul 30, 2010 | Westell Wirespeed VersaLink...
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
I have a Westell 327 router and a new laptop running Vista Business - I can access wireless internet, but it is showing as unsecured - this wasn't happening on laptop that just crashed - I have tried...
It's possible you are connecting to a neighbor's unsecured network by mistake. Have you verified that you are actually connecting to your own network?
Jan 10, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
Remote access through a Westell Wirespeed Versalink model B90-327W15-06
Garbow,
You need to setup a feature called "Port Forwarding." Do you know what program you will use to access your desktop remotely? I recommend windows windows remote desktop or VNC programs.
The link below is a complete walkthrough on how to enable port forwarding for windows remote desktop from a westell 327.
http://www.portforward.com/english/routers/port_forwarding/Westell/D90-327W15-06/Remote_Desktop.htm
There is an alternative option called a DMZ which you could use. Let me know if you need further assistance.
Apr 12, 2008 | Westell Wirespeed VersaLink...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Default Password
the default password for your westell 327 is username: admin and password: password, the admin admin combination is what usually isp providers such as verizon tells you to put in after configuring it for the first time. 192.168.1.1 is the url add for you to be able to access your westell 327. after accessing your modem you can find the WEP key below the modem, after enabling the security of your network the WEP kep is your default security password
Dec 12, 2007 | Westell Wirespeed VersaLink...
How to change wep security key
hi, sometimes if changes was done you need to recofingure you're wireless all over especially if the key has been saved on your pc to be rembered, you could actually reset your router and configure it by going to your routers gateway by doing an ipconfig you'd be able to see the gateway..launch it in your browser n youd be able to access the configuration of the versalink...i could actually give you more detail though im in a hurry, better you call your isp provider or bellsouth now att since westell versalink are manufactured by them and they give great tech support for connectivity problem...
Nov 28, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
121 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
B.Th. Pluijm
B.Th. Pluijm
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
