Installation of RAM
Hi I have a Samsung tablet pc NPQ1. I wish to upgrade the Ram, but how do I access the modules? Do I have to remove tthe back - I cannot see any panels behind which they might lie. Many thanks
woodbowls
  • woodbowls Mar 13, 2008
    many thanks, I figured I might have to resort to dismantling the thing!
    Scholar:
  • 99 Answers
There should be a panel on the back that would have the memory under it. if not then you may have to remove the entire back to get at it.
Posted on Mar 13, 2008
Install ram in toshiba pa3171u-1mpc
Hi Kappaman,
This is an easy upgrade to make, check the bottom panel of your machine, you should have some removeable acess panels, usualy held by a number of small crosshead screws, once these screws have been loosened you should be able to remove the panel. The Ram modules are roughly 2 inchs long and slot into slots on the mainboard there will be small clips that hold the ram in place, push these away from the edges of the ram modules and the ram will flip up. this allows for removal. Look for identifying marks to buy replacements/upgrades. Simply push the new items into the slots at an angle (like the previous ram after pulling the clips) and push down to a flat position. You should hear the spring clips click into place. Hope this helps.
Feb 18, 2013 | Computers & Internet
How do I fit extra memory in my acer aspire z series
If there is no Random Access Memory (RAM) compartment cover on the rear or underside of this computer, then, as is common with All-In-One (AIO) computers, a degree of disassembly is required in order to access the RAM Module slots internally.
If so, unless you are experienced at the disassembly and internal repair or mopdification of AIOs, Liquid Crystal Display (LCD) or Light Emitting Diode (LED) Personal Computer (PC) Monitors and LCD or LED Televisions (TVs), my advice would be to take this computer in to have the RAM upgrade performed by an authorized Acer Service Center.
The internal areas of AIOs, LCD, LED PC Monitors and LCD or LED TVs are u highly unsafe and inexperienced user-unfriendly working environments because such devices contain Electrolytic Capacitors (e-caps) that are storage devices capable of storing dangerous and even lethal charges, even when the device is completely disconnected from the mains electricity. Some capacitors can store charges as high as several tens of thousands of volts.
The aim would be to remove the back panel.
Often (but not always) with AIOs, LCD, LED PC Monitors and LCD or LED TVs, the key to removing the back cover lies in first unscrewing and removing the stand.
Look out for hidden screws, particularly deep-set screws, some of which might even be completely obscured by a warranty sticker or other label, meaning that upgrading the RAM in this computer within its warranty period might invalidate the warranty unless the upgrade is performed by an authorized Acer Service Center.
When the rear cover is removed (some additional internal panels might need to also be unscrewed/unclipped and removed), you should have access to the four RAM Module slots. Two slots should be free and the remaining two occupied, each containing a single (2048 Megabytes) otherwise referred to as 2 Gigabyte (Gb) RAM Module, because the standard RAM specification of this computer is 4Gb. The maximum specified RAM for this computer is 8Gb, meaning that either one or two 2Gb Modules can be added during a RAM upgrade.
The specifications of the RAM Modules for this computer are:
240 Pin 1.8v DDR3 PC3-1066 Non-ECC Dimm (240 contact elements, 1.8 volt, 1066 GigaHertz Oscillation Cycle Clock Speed, 3rd Generation Double Data Rate, Non Error Checking and Correction, Dual Inline Memory Module).
Nov 30, 2011 | Acer Computers & Internet
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
RAM upgrading loses display
Hi Mike, I take it you have just tried to go for a ram upgrade and now you have nothing showing on your computer screen. Do you still have the old ram in your system? I'm thinking you can perhaps remove the ram upgrade and see if this has any effect in getting your system back up and running. It could be a faulty ram module. What was your ram before the upgrade, 512, 1GB, 2GB? Another thing to consider before touching the inside of your pc make sure you ground yourself and you can do this by touching the outside metal port at the rear of your pc and this will then release any static discharge from your fingers.
Here's a website for you to check also and this is where I purchase my memory from and it has this free scanning tool that scans your system and it tells you how much ram you have in your system and the maximum amount of ram that you can install in your system. http://www.crucial.com
As things stand, I would remove the ram upgrade and stick with the ram that you had before the upgrade and then check out the crucial website and carry out that scan. I hope this information is of some use to you and good luck. Andrew
Apr 05, 2011 | HP Compaq d530 CMT PC Desktop
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Rgds
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
How to install RAM?
You can get detailed description of how to install the ram in the below link
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Toshiba Tecra M7 Tablet PC
Ram Install access upgrade
Below the Notebook There will be access flap to put the ram. May even you need to Keyboard for few models.
Mar 11, 2008 | Acer Aspire 7720 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
