Gestetner 2302Z copier
What does the C-32 or C-36 error message mean? And can we get service manuals and part manuals for this copier? We have the user manual but it is pretty simplistic.
    New Friend:
  • 120 Answers
C-32 is a scan reverse problem. there is no c-36 code. If you mean c-63 it is a fuser thermistor problem. Lawrence. I have a service manual for the Mita 1435 which is the same machine. The scan reverse code could be dirty rails where the optical assembly. ( the light that goes back and fourth) Clean and lube the rails.
Posted on Jun 03, 2008
SOURCE:
WHY THE TECHNICIAN CAN NOT IDENTIFY THE PROBLEM UNDER THIS CODE- SC561
The error code details will b edescribed in the service manual [repair manual]. Try this link to download it.
DirectPDFs com Gestetner Repair Service Manual Downloads
Electro help
Jun 04, 2014 | Gestetner Office Equipment & Supplies
Gestetner Dsc445 service code error
have you checked/replaced the thermostats?
this may also be a problem with your hvt board or power supply.
Feb 26, 2013 | Gestetner Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Copy prints with image from previous page (lighter) as well. This is an older copier (Gestetner 2302Z)--is the fuser roller the issue/ Can I repair/replace myself?
To check if it is the fuser rollers turn off the copier before the paper reaches the fuser.Remove the 'jammed paper' carefully as the image will rub off and see if the double image is present.If it not then it sounds like the fuser.If it is there then will more than likely be the drum that is not cleaning.I do not suggest that you change this yourself.
Nov 01, 2009 | Office Equipment & Supplies
I have a Gestetner 3245 With Code SC 322-00 call for service message on. What is it, can it be fixed or reset. I bought it used to use in my classroom. Thanks
Hello sir; The error code you display on screen, it means laser unit have problem, it can not be reset but it can be fixed, you have to call your local technician to help you.
Oct 13, 2009 | Gestetner Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
Gestetner 2302z photocopier toner light stays on but has toner in it
The error code has got something to do with your fuser. Either the lamp is blown, the thermistor could just be dirty or the fuse has blown. These manuals are very old, do not know if it will be easy to get the manual.
Mar 11, 2008 | Office Equipment & Supplies
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
167 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
