Question about Dryers
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
FER231AS2
    Sergeant:
  • 288 Answers
Sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Posted on Mar 13, 2008
SOURCE:
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
Control lights come on briefly, then turn off, dryer will not run
make sure your getting 220v from the receptacle . good luck APPLIANCES R EN
Mar 02, 2013 | Maytag MDE4806 Electric Dryer
Bad motor for pyg2300aww gas dryer?
How stiff is the motor? You can lube them sometimes and free them up for a while:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 22, 2012 | Dryers
I'm pressing the start button but the dryer won't start. it just beeps about 3 times then stops. The first time i tried it it ran for about 5 secs then shut off.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My Kenmore dryer won't stay on when you push the start button it starts and turns off real quick. I have gotten new fuses and replaced them and it still won't work.
heatman101
Jun 01, 2011 | Dryers
My controls locked button light is on, pressing cycle button for 3 seconds does not turn it off. any other suggestions? thanks
Unplug the unit from the wall for 2 min's then plug back in and depress the lock button and hold until the beep or light shuts off. Sometimes it will take more than just 3 sec's and sometimes as long a 20 sec's,
Apr 02, 2011 | Kenmore 87562 Dryer
My 8yr old Magtag PYET244AYW dryer is getting worse...
check the air flow at the exhaust,
you should have a good and steady flow while the dryer is running.
sometimes cloggs happen in the middle of the exhaust line
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Problem with speed queen 30EG. Dry ignitor turns on trying to turn on the burns but the dryer turns off in about 5 sec. If I turn off the gas valve the dry stays on.
Sounds like the thermistor. It is the whit plastic piece on the front of the motor - blower assembly with 2 wires going to it.
Aug 24, 2009 | Speed Queen CES68AWF Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
